Question about Master Heaters B200BT
Need diagram of the fuel pump mech. on the B-200
Internal diagram
  • 26 Answers
Http://www.bealsmotor.com/manuals/102569-01.pdf You can find the owners manual at this link
Posted on Dec 01, 2014
I need the mechanical fuel pump for 2004 Isuzu Axiom
Carter would carry the fuel pump you need. They are well known suppliers for carburetors, pumps , and fuel management components
Feb 13, 2015 | Isuzu Cars & Trucks
Fuel shut off switch location on a 74 alfa romeo spider 200
Does the fuel pump run? The inertia switch, if tripped will prevent the fuel pump from running. If the pump runs but the car doesn't start than it's likely a problem with the fuel pressure regulator or the bypass internal to the pump.
Jun 04, 2014 | 1974 Alfa Romeo Spider
Impeller rubing on the housing after motor starts.
The motor bearing on the pump end may have failed. Looks like this pump cost about $200 so having it inspected and repaired may be close to that. Unless you know someone who works cheap or you have some mech abilities. Here is a link to an exploded assembly parts drawing.
http://mypool.com/images/parts-diagrams/Polaris-PB4-60.jpg
Nov 15, 2013 | Polaris Pb4 - 60 Booster Pump
Can you put a mech. fuel pump on a 94 GMC sierra it has the plate on the block were a mech. fuel pump can go
Remove the plate and check for a "piston" or rod that needs to be there to run the pump off the camshaft. You will see a hole in the casting where it will slide. It will be angled up into the engine. If you have that then you have to find out which fuel pump to use, GM had two. One with a long push arm and one with a short push arm.
Your best bet might be to find a donor engine in a scrap yard for the cam follower and take your cue from it's fuel pump.
Sep 17, 2013 | 1994 GMC Sierra
Carb 740cuts out while driving fuel filter empty
Check in tank priming pump, also check inline fuel pump. runs only while eng. is rotating.
Dec 27, 2009 | 1990 Volvo 740
Car would not start. Mech stated had a fuel pump
sound as a grounded B+ wire (voltage supply), sorry but need a good honest electrician, he might need to tear down electrical harness to trace, find and repair if possible grounded wires, hope is not too much damaged
Nov 17, 2009 | Chevrolet Tahoe Cars & Trucks
I cant find the fuel filter in my 2005 kia sportage, my mech tells me its in the fuel tank
Your mech is correct; this vehicle utilizes a strainer on the fuel pump only, and a submersible fuel pump. To access this, usually the tank has to be removed, and the pump can be removed from the top of the tank.
Oct 20, 2009 | 2007 Kia Sportage 4x4 V6
1992 Saturn SC Fuel Pump Problem
You need to get the schematic / wiring diagram . There is a junction block in the center console where the wiring is routed to the entire car. The contact on the power wire to the pump gets burned /dirty and becomes intermittant . It needs to be cleaned .This happened to me twice.
Feb 10, 2009 | 1993 Saturn SC1
I need a 2002 ford ranger fuse box diagram and afuel pump relay switch diagram
Hi
go to www.motorcraftservice.com then click on the owner guide and put in your truck information
then choose the 1st owner manual printing and should be between page # 184 to 200.
Good luck and I hope this will awnser your question.
Oct 27, 2008 | 2002 Ford Ranger Regular Cab
Master Heaters B200BT Logo
50 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Mike Squire
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
