Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Error message file too large - LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
I cant copy a big file (example: ISO file size 7gb) into my transcend external hard disk 500gb. a pop out message will appeared (File too big to transfer) help me please. Thanks
Please check how many Mb free disk space you currently have on your transcend device as the description of the pop up message sounds like the default error message from the operating system stating that the file you're trying to transfer is too large to fit on the destination drive. Perhaps try copying and pasting a smaller file first just to make sure that there's nothing wrong with the drive before attempting to transfer such a large file.
Apr 12, 2011 | Computers & Internet
Tip
How to receive large files through bluetooth in nokia 5800
You can receive large files in your phone if you have enough memmory on your memory card.If we receive a file through bluetooth , it will be stored in the message inbox.So if we try to receive a large file,the phone says not enough memory to receive.You can avoid this problem by changing the storage memory for messages.Before receiving large files through bluetooth,go to messaging.Then select options.Select the settings.Then select other.There you can see an option for memory in use.Select it and change the memory in use into memory card and press ok.Then receive the file through bluetooth.After saving the file,you can change the memory in use into phone memory.Thanks.
on Jan 08, 2011 | Cell Phones
Where do find 'Browser configuration'. I am getting Error 413 message ''Entity too large'' on a website and some adice to clear it was to go into 'browseconfig' and check frst two boxes. Need to find...
Error Message: "413 – Request Entity Too Large"
Translation: The Web server has determined that the data being sent by the browser is simply too large (that is, too many bytes). This occurs when file size limits are exceeded. For example, when uploading a very large file (using a technique such as HTTP PUT), a 413 error may be returned when the Web server sees that the file size is too large.
Solution: This error is typically due to configuration or programming errors on the Web server end. It may be possible to shrink the request entity (such as uploading a smaller file). Otherwise, the Web server will need to be reconfigured to accommodate the larger entity. You should inform Webmasters of the offending sites about the trouble.
If you are using a proxy you may have to configure it to allow large packet transfers.
Jun 02, 2010 | Computers & Internet
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
I cant move large video file from my laptop to my 1TB WD Drive
Reformat the drive from Fat32 to NTFS.
Largest file size on Fat32 is 4 gig
Oct 14, 2009 | Western Digital My Book Essential Edition...
49.3046 Error To Continue Turn then On
Disconnect cables (except power) and try turn it on. If message dissapears be sure that you delete all pending files to print in your computer (specially large pdf).
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
My designjet 500 plus won't print large PDfs
What error messages do you get? Any at all or just no output?
How large are the PDF files you are trying to print?
Dan
May 08, 2008 | Office Equipment & Supplies
Pictures cannot be download
When you try to transfer a large number of files (or a single large file) from a PTP (Picture Transfer Protocol) device, such as a Sony Memory Stick, you may receive an error message saying that your computer cannot detect your camera or that, although it has detected the camera, the current picture cannot be copied. This happens because in older versions of WinXP the PTP driver limits file transfer to 2,048 files at one time and those files must be less than 210MB. If you update WinXP with Microsoft's latest service pack you should eliminate the problem.
Feb 22, 2008 | Fuji FinePix A345 Digital Camera
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
16 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
