Question about Dometic 57915531 Air Conditioner
Why is the red ied flashing on my dometic 1600plus
Can't get the unit to start,it goes then stops & the light starts flashing
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: , Compressor start capaciter MFD value: roof top RV Dometic unit
Hi, I did some research and found nothing on the a/c unit. If I had the model and serial numbers from the condenser and compressor this would help me. This would be a run capacitor doing the start up, dropping out the start relay and keeping it running. If you have only one run capacitor and its a dual, will have 3- female spades coming from the top, with marks that say Fan, C for common, and Herm. for compressor. If it has only one capacitor with2- female terminals, several places to connect more than 2 wires, its a single cap. If it just runs the compressor, it could be a 370 volt x 20, 25, 30, 35, uf?? If its a dual it could be a 370 volt x 5 u f for the fan and the same , 20, through 35 u f or microfareds. The best way to find out is to take off the wires on it, and make sure you draw a diagram so you know they are right, and take it to a appliance parts house and let them check it to see what they are. Larger units can have a 440 volt x 20 to 35, 40, 45 and so on. Your unit is not that large, so it will only be 370 volts as far as voltage, but the u f value will need to be checked with a meter that will check the value of these and give you a number such as 4.99 u. f. and you will no its a 5 u f. It may be higher like 5.24 u.f.and that is OK. Make sure the capacitor has no oil leaking from it or its not swollen looking or distorted in anyway, it will be open or shorted out. Please let me know if I have been of help to you when you go to rate me, please be kind. I will be here if you need my help if you are having problems with the compressor not starting.
Sincerely,
Shastalaker7
A/C & Heating Contractor
PS If this capacitor is black plastic and mounted on the side of the compressor, it will be a start, run capacitor with 2 wires. It snaps in a metal type holder you will need to take it out and check the terminal area it was connected to and remove it. If only 2 wires, it won't make a difference what side the leads hook to.
Posted on Jul 03, 2010
Testimonial: "This is exactually the information I was looking for. The paper label on the black plastic cse was faded, and I wasn't sure of the u f range this comperssor needed. Thanks, G"
Why is my flue injection light keep flashing?
Have you changed your Exhaust on your Motorcycle? There is a Cable that goes from the Flap. This happened to my GSXR
Jul 17, 2014 | 2003 Suzuki GZ 125 Marauder
On my whirlpool ADP962 dishwasher the start light is flashing but nothing is working. I can change the programme type (ie rinse, wash etc) but the programme will not start. I can't select either half load...
check the thermal cutoff located inside the door for continuity and check the heater to assure this is working as well you can also do continutity test on the heater if the heater is not functioning properly then unit will go no further into washing the same with the thermal cutoff if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Apr 26, 2011 | Dishwashers
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Will not power up starts and then stops flashing
This is known as the yellow light of death for the ps3(ironic i know because it blinks red). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty with this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c921F5935-E460-55B7-A328-5BEA7D5C49AE_kDAFA2718-297A-1EA2-6192-44C4B1E6348C
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 switched off during an online game (not a power failure). it gave a flshing red light as if shutting down. However, it just sits there flashing. I shut down the power and reapplied - the...
this is whats known as the yellow light of death (ironic i know since the light is red). your unit will need to be professionally repaired in order to work properly. check with sony to see if your unit is under warranty at this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_cEAAC34B3-EB87-3418-0E31-7DFCB50B79FA_k5CC13D12-5188-1981-F23C-95AE6A57CEE7
if your unit is no longer under warranty, go to www.wiredextreme.com. we'd be glad to fix this problem for you. all of our repairs come with a 90 day warranty that covers the whole console, not just what we fix. we also offer extended warranties for up to 4 years at an additional cost. you can contact us at 214-222-5788 or support@wiredextreme.com
Jan 14, 2010 | Sony Playstation 3 (PS3) Console
Red light flashing inside the unit. Is this a
Generally speaking it is not, if it is a slow steady flash, this is referred to as the "heartbeat" by techs, if the unit is operating correctly that would be my assumption that it is just a "status" light
Jul 14, 2009 | Dometic Rooftop RV Air Conditioner
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Dometic 57915531 Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
