Question about Goodman Heating & Cooling
Is my goodman Ckl36-1F a heat pump or just air conditioner
Serial 02005400858
    Genius:
  • Goodman Master
  • 1,363 Answers
Just a/c
Posted on Aug 14, 2015
kstfas
  • 75 Answers
SOURCE: goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Posted on Aug 31, 2007
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
pierre1811
  • 144 Answers
SOURCE: Need to know how to find out how old my furnance & air cond. is
1993
Posted on Mar 31, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
  • 53 Answers
SOURCE: goodman air conditioner tag model is CK36-18,
sir you have a 3 ton unit
Posted on May 17, 2010
I am installing a heat pump, and i having 8 flashes at my green LED .
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code
http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Oct 06, 2013 | Goodman Manufacturing Goodman DSZC160601...
Capf3636c6ba
That is a 36000 btu inside unit.
That is a 24000 btu heat pump.
The heat pump is undersized and that will never work out.
Sep 04, 2013 | Goodman CKL36AR36 Air Conditioner
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
Jun 16, 2009 | Goodman CKL60AR60 Air Conditioner
I have a Goodman Heat Pump System Model ARUF032-00A-18,
That sounds to me like you lost your low voltage power. Bad transformer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Goodman CKL30AR30 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Heat Pump or not???
This is an air conditioner. Based on the numbers you gave me, this is what I come up with. Thanks.
C= Split system
KL= Air conditioner
30= 2.5 ton
1= 208 230 v
D= Revision
Jun 23, 2008 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
