Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Where is the booster located on the hobart am 15
Hobart lx18h Booster does not heat up. machine powers up and will wash thouugh all cycles but the booster does not heat up water.
There are one or two hi-limit relays on the booster. One is on the front and if there is a second one, it is on the right hand side as you face the front of the unit. They are both manully have to be reset if tripped. Check them and also the booster's contacter
Oct 03, 2016 | Hobart Dishwashers
I have a hobart commercial dish machine Am14 that the spinners for final rinse are not spinning I have water pressure around 15-20 psi any thoughts?
That water pressure is fairly marginal for a machine without a booster pump.
I'd be looking to cleanout the debris strainer in the water supply: you may have a separate strainer, it may be at the inlet side of the water valve, it may be in the form of a mesh at either end of the fill hose.
If your water is hard, there may be a restriction formed by limescale at the boiler outlet.
Feb 13, 2015 | Hobart Dishwashers
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart LX 18 needs compatable booster heater
A hatco C9 or C12 would be plenty big enough.I would use the larger kw unit if incoming water is very low,but it needs to be 140 degrees coming in so it doesnt sometimes trip the hi limit.
Oct 11, 2008 | Hatco C 24 Compact Electric Booster Water...
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
19 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
