Question about Lexmark Optra S 1855 Laser Printer
Have an Acer Aspire V5-572P-4429 Laptop and a Lexmark E323. Show the printer has connected because the diagnostics test sheet prints, but I can't print from my documents file. Message received: Error printing. What's the fix?
SOURCE: Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Posted on Feb 19, 2008
SOURCE: Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Posted on Jan 14, 2009
rjwharris
  • 102 Answers
SOURCE: Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
Roop1980
  • 228 Answers
SOURCE: Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
If this does not help the situation, please describe any differences it does make.
Posted on Apr 17, 2009
  • 323 Answers
SOURCE: Printer installed fine, won't print. Error code 0x0000007e?????
First make certain a USB cable is attached to your printer and to your USB. The windows install device will tell you it has located new equipment and ask if you want Windows to install it. If you didn't go through this before, allow Windows to install it. Use the disk that came with the printer if you have it. (Make sure the drivers on the disk will run on Vista. The disk should tell you. Lexmark 7100 series was introduced a ways back).
If you've gone through this, and you know it is installed correctly, with the proper drivers, go to "Control Panel". Choose Device manager, and click open "Ports (Com &LPT).
Choose Communications Port (Com 1). Opening that will give you the Properties page. Click Resources at the top of the page. About halfway down the page will be a small box that says "Use Automatic Settings". Make sure this is clicked. It gives Window permission to find and use the best generic drivers for your printer, among other things.
At the bottom should be another box entitled Conclicting Device List.
It should say in the box "No Conflicts." Click OK to exit that box if all is well. Next, go back to Control Panel again. Look for and choose "Printers". Among other selections, you should see an icon of a printer that says Lexmark 7100 series. That should have a big green checkmark by it in a circle. If it doesn't, click on the icon and a small box will open in the upper left hand corner.
It should say "Lexmark 7100 Series". If it does, click on Printer, then click add as default printer. Then when you close the box you shouls see the icon marked Lexmark 7100 series, with the green checkmark inside a circle.
If you don't see all these things wirite back and we will take the next step.
Sirwriter
Posted on May 17, 2009
Trying to find the printer drive for a Lexmark X4850 that I can download to printer from an Acer Aspire laptop running Windows 8 64bit
The last operating system that supported that printer was VISTA. You can go to the lexmark site and download that driver and see if it will work with that computer. Even the HCL page for windows doesnt show any information on it and Lexmark says that printer is not in production any more.
Apr 14, 2014 | Lexmark Office Equipment & Supplies
Good morning, I bought a acer aspire 7540G laptop with Windows 7, 64 bit. I connected the Lexmark Optra S 1855 printer with the USB but my computer cannot find the driver. Where can I find the correct...
You may click on the following links below to download the available printer driver for this printer model.
http://bit.ly/oLHVX3 - 64-bit PCL XL Emulation Print Driver Universal Print Driver
http://bit.ly/p0RF71 - 64-bit PCL 5 Emulation Print Driver Universal Print Driver
http://bit.ly/oOi99g - 64-bit PostScript Level 3 Emulation Printer Driver Universal Print Driver
For further assistance, please contact Lexmark Technical Support
Jul 26, 2011 | Lexmark Optra S 1855 Laser Printer
I have connected "Lexmark E323 " printer to my p
What Version of Windows are you running. update driver for your os at Lexmark,com
May 25, 2011 | Lexmark E323 Laser Printer
Desperately in need of lexmark laser printer e323 drivers for windows xp
Try to find at yahoo or msm websearch to get free printer installer software for your printer. Just type the model print and you can download it for free.
Nov 11, 2010 | Lexmark E323 Laser Printer
I want lexmark E323 free drivers for windows 7
Download the complete universal driver for Lexmark E323 printer for Windows 7 from the Lexmark website at http://bit.ly/a94qNR. It includes 32-bit and 64-bit drivers for Windows systems. Thank you for choosing Lexmark.
Sep 21, 2010 | Lexmark E323 Laser Printer
I have a LexMark x7550 all-in-one printer, model:4429-W22, serial #: 01360113314 2007/09. Printer will not print internet download or regular documents. I unpluged the printer and rechecked connections,...
Please go to run and enter "devmgmt.msc" you will get device manager, Remove all of the Universal Serial Bus from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the all in on printer and install the software properly.
Aug 07, 2010 | Lexmark X7550 InkJet Printer
How do I hook up my Acer Aspire laptop to my Epson printer?
You can hook up Acer Aspire to your Epson Printer Using the USB Port if the printer supports the USB port A type. I am not sure what model of Epson printer you are using. You may have to configure the printer either by going into add remove hardware and scanning for hardware changes and installing the Printer, or may have to put the Driver CD provided to you by the driver manufacturing company and install the driver which will also allow you to print a test page at the end of installation to give you a clear picture that the installation was successfull. Please ensure that the printer is connected to the laptop and is powered on while giving for a test print. Good Luck.
Feb 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Lexmark E323 drivers
http://www.driverstock.com/download-Lexmark-E323-driver/12-26-1945/index.html
You can download the driver as per the operating system used in your computer in the above site for which i have provided a link.
Oct 20, 2009 | Lexmark E323 Laser Printer
Error printing from my loptop acer aspire 5520
Hi there!
Try to reinstall the printer driver on your Acer Laptop. Hope this solves the problem.
Mar 06, 2009 | Acer Aspire T135 PC Desktop
Lexmark Optra S 1855 Laser Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
