Question about Furniture
Virtuu Floretine 31-inch Single Sink Bathroom Vanity
2 Suggested Answers
  • 12 Answers
SOURCE: I'm wondering if I should get more shelves or more drawers in my bathroom vanity
I'm a drawer's person - I love drawers since you can pull them out and don't have to bend every time, like you have to with shelves. I would lose all the shelves and have only drawers. From the designer's perspective, I find drawers are better looking than cabinets.
Posted on May 29, 2012
Need assembly instructions for kokols pedestal combo sink in clear
Is this any help?
https://sites.google.com/site/bathroomfurniturevanitysink/installation-on-vanities/glass-vanity-set-up-guide-kk09
Otherwise you could send them an email:
http://www.kokolsinc.com/pages/contact-us/
Apr 20, 2015 | Kokols Clear Vessel Sink Pedestal Bathroom...
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
How to install a bathroom sink on vanity
It's as simple as getting the right size vanity top and a tube of silicone
Jun 20, 2014 | American Standard Home
How to connect a vanity 2 inch drain pipe to a three inch toilet drain pipe
You can by 3">2" rubber adapters from most plumbers merchants for a few quid
Jul 07, 2012 | Furniture
Im looking for large and long antique vanity for my bathroom
You may want to get the 3 or 4 sink antiquevanity. On the net you can try this website: http://www.bathgems.com/antique-vanities/on the right side you can sort the vanities by . Good Luck!
May 29, 2012 | Furniture
I have an American Standard single handle faucet in the bathroom.. When you open the faucet fully the flow rate is very small. The faucet was fine before. How do I adjust the faucet to so that the flow...
What is likely happening is a small piece of sediment has become lodged in either the mixing valve or in the aerator.
Begin with the easiest part first. The aerator is the threaded attachment from which the water comes out of the faucet. Remove the aerator from the faucet and run the tap without it installed. If the flow rate is good either clean or replace the aerator.
If this was not the problem then the solution becomes much trickier because the obstruction is likely in one of the lines coming into the faucet or in the body of the faucet called the mixing valve. This is where the hot and cold water mix inside the faucet.
Our next step is to create negative pressure inside the faucet in an attempt to remove the buildup restricting the flow.
If you don't have shut off valves under the sink you will need to shut off the water supply to the home, remove the faucet from the vanity/sink and perform the following procedure.
Shut the hot and cold water off underneath the sink and remove the supply lines at the shut off valves but leave them connected to the faucet. You will need to purchase two adapters for the aerator that will allow you to connect a garden hose from your closest water supply (kitchen sink) to the vanity faucet. You can find these at your local hardware store. You will also need a pail under the vanity to catch the water coming out of the vanity faucet supply lines. Connect the garden hose from an active water supply to the vanity faucet. With someones help have them turn the water supply on which will then run backwards through the vanity faucet and into the pail underneath the vanity. Be sure to open the vanity faucet taps to full so that water will run through the faucet. This should dislodge the obstruction.
Jul 24, 2010 | American Standard Ceramix Monoblock...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
How do I contact Pegasus to obtain missing parts?
Pegasus is Home Depot own brand of bath room fixture. The contact number should be on the installation instruction or the warranty sheet.
you shold contact Home Depot if you cna't find the contact number.
Mar 28, 2009 | Pegasus Technologies Pegasus Pegasus...
Furniture Logo
98 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
