Question about Mitsubishi Projection Televisions
Mitsubishi projection TV will not show picture
Will not show a picture but it has sound and will show the channel #. I believe it could be a bulb but i do not know where to look.
5 Suggested Answers
  • 208 Answers
SOURCE: mitsubishi projection tv vs60va2 picture rolls
This unit has chroin bad caps on the 5v, 9v and 12v regulators. If you know circuitry you can check thos caps and replace the weak or open electrolytic caps. If you call on a tech that services mitsu. this is faily common repair for them and should not cost over 150.00 to 200.00 depending on your area.
Posted on Apr 07, 2008
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
  • 1187 Answers
SOURCE: Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Posted on Jul 12, 2009
  • 5081 Answers
SOURCE: Mitsubishi TS-5053 rear projection TV-Sound but no picture
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Posted on Oct 19, 2009
Testimonial: "Thank you for your help. This is a really great service. Doug Little Elm, TX"
  • 3459 Answers
SOURCE: 62" mitsubishi tv wavy picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
0 characters
1 Points
Has sound but shows no picture
These types of TVs eventually need to have the bulb replaced. There should be an access door marked on it somewhere. Google your tv brand and model to find a replacement bulb.
Nov 26, 2013 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi model wd=65c9 when turned on green light blinks repeatably sound comes on but no picture
The bulb that lights your picture is burned out. Buy a new warranted bulb from $85 with the housing. You can replace this yourself in 5 minutes. Shop jimmy has a video showing replacement. Remove 2 screws that hold the housing in place, slide the bulb out and slide the new bulb with housing in and replace the 2 screws. Plug in and enjoy your tv.
Feb 23, 2013 | Mitsubishi Projection Televisions
Want does yellow light mean
If I'm not mistaking I believe Mitsubishi shows the yellow light to indicate new bulbs needed and or overheating. Most common is overheat, but may actually be a bulb replacement required.
That is the manual for your TV
Mar 10, 2011 | Mitsubishi WD-73733 73" HDTV
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Projection Televisions
Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Feb 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projection Televisions Logo
50 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
