Question about Husqvarna Zero Turn Mower Z5426
After 30 to 45 mn. Rt. side won't steer - Husqvarna Zero Turn Mower Z5426
Steering wheel won't turn
Shake steering wheel side to side pushing in on the key while Turing the key to the off position
Apr 16, 2013 | 1995 Mazda 626
I am looking at buy a 1999 rt 1100, it has 'cupping' on the front tire, what causes this?
If you run low tire pressure you can get cupping on the sides of the tires. Tire pressure needs to be checked regularly and kept at the recommended pressure or above.
Another cause of tire cupping can be bad or loose steering head bearings. Loose bearings will cause the wheel to wobble when decelerating just like low tire pressure. It can sometimes be detected just by turning the handle bar from side to side. If it feels like the steering wants to lock in the driving straight position or you feel ripples or bumps while you turn the bar from side to side you need new steering head bearings and races.
Jan 08, 2011 | 1999 BMW R 1100 RT (ABS)
Block number location
UR #,S R LOCATED ON FRONT OF BLOCK TO THE RT SIDE NORMALLY....NEAR UR POWER STEERING PUMP...WHT DO U NEED TO NO ABOUT UR GALLANT?> CHARLIE
Mar 06, 2010 | 1991 Mitsubishi Galant
Horn dosent work
Step 1 is to ck the horn fuse in the under hood fuse box. If it is good then disconnect the rt horn (the easiest one to get to under the rt hand side front bumper.) /connect a test light across the 2 wires have some one push the horn pad and watch the test light . If the test light lights then the horns are bad and need to be replaced. If the test light does not light then remove the steering wheel air bag and ck the horn wire under the air bag.
Feb 24, 2010 | 2003 GMC Yukon
1993 cavalier changed blinker suignals still just turn on wont blink
Are you sure you got right flasher. 4 ways (hazard) flasher is on drivers side (left side) of steering column, in convenience center, and signals flasher, is on steering column, under dash on passenger side (rt,side)
Nov 27, 2009 | 1993 Chevrolet Cavalier
Husqvarna Zero Turn Mower Z5426 Logo
18 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
