Question about Avery Computers & Internet
Foil labels smear when printing with HP 2055 - Avery Computers & Internet
Nitrotrike
  • 589 Answers
SOURCE: Toner Does Not Adhere to any Type of Labels
You need to specify that you are using labels in the printer properties, so the printer raises up the fuser temperature for printing on labels.
If you have the user guide, instructions are on page 28, chapter 5.
If not, here's how:
1. Open the straight-through output door.
2. Open tray 1 and adjust the media guides to the width of the media.
3. Load media in tray 1. Make sure that the top of the media is forward and the side to be printed on
(rough side) is facing up.
4. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
5. On the Paper/Quality tab or the Paper tab (the Paper Type/Quality tab for some Mac drivers),
choose the correct media type.
Posted on Feb 07, 2008
  • 401 Answers
SOURCE: hp 2055 cannot print pdf
UNCHECK PRINT TO FILE CHECK BOX
Posted on Mar 09, 2010
  • 224 Answers
SOURCE: Repair on Hp laserjet 4250. Printing but smearing ...
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
Posted on May 14, 2010
  • 899 Answers
SOURCE: After printing label, the toner smears on the
A magnetic drum is charged up where the toner needs to go on the paper. This attracts the particles of toner to the paper. The toner is not wet or sticky, it is a dry powder. To fix it to the paper, the paper is passed a heating process. The heating element may not be working. Or the unit may need cleaning to remove toner deposits.
Posted on Mar 03, 2011
e-Guru
  • 3917 Answers
SOURCE: No matter what paper type
Hi
Go to Start
Control Panel
Printers
Right click on the printer in question
Paper/Quality
(Plain Paper) This is a pull down menu with all styles of paper. You can change to the paper that you are using and change other settings as well.
Also it could be as simple as a bad pickup roller in the tray 1 not moving the paper in the allotted time and you get the error. Try cleaning the roller with warm soapy water, but most likely it needs to be replaced.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 27, 2011
HP6500 won't print on foil
Most inkjet printers need a paper that has an absorbtion rate of +.ooo5 but unless the foil is a coated stock I dont think the ink will adhear to it..Try a differnt stock . Maybe a bad batch of labels..and did you use HP printer ink or are your cartrages refills??
Dec 20, 2013 | Office Equipment & Supplies
I am having a problem with the wax ribbon smearing on a thermal label after I imprint on it. Is going to a resin/wax ribbon the only answer?
Not necessarily. It could be a head adjustment. If you are just printing on a blank thermal transfer label stock then wax should be just fine. If you are printing on a colored stock then a resin/wax would be better. We use resin/wax on everything because it is the same cost and runs better. But if you have only blank paper wax will be fine. If you are smearing then I suggest adjusting your head. Even if it printed fine before as your platen roller wears down it will require slight head adjustments to print properly
Jan 12, 2011 | Datamax I-4208 Thermal Label Printer
Ink smears on photo prints- in never dries. This is a new problem,
HP ink is water soluble. It comes off or smears onto a damp finger. So now I have an issue with HP.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
How do I format a Word document to print on a Maco gold foil certificate label, ML-7850? Thanks.
Maco Laser Gold Foil Notarial & Certificate Labels
Personalize awards using your own laser printer.
* Can be used for legal documents, certificates, embossing and more.
* 2 1/2" diameter with serrated edges.
* Designed for laser printers only.
Choose the correct label size from the page setup in MS Word.
Apr 13, 2009 | Computers & Internet
Only prints ''smeared labels'' with no text even remotely recogniza
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Feb 19, 2009 | Datamax E-Class E-4203 Thermal Label...
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
If not, here's how:
Feb 07, 2008 | HP LaserJet P2015dn Printer
Computers & Internet Logo
20 people viewed this question
Top Avery Computers & Internet Experts
Donna Sander
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
