Question about Saeco Easy Espresso Machine
What does the brew light look like
What does the red light look like
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
My brew group was stuck, followed instructions and got it out and motor turned to correct position. Put it back together and now nothing...green light comes on and thats it. No motor sound, that's i
Unfortunately I cannot locate your problem or duplicate it. The various units that turn on the red "stop" light are the grounds container, the drip tray and the brew group. When they are reinstalled the light goes out . So if your brew group was stuck and you had to force it out then you should check very carefully that there are no cracks or breaks on the back. Remember this, the brew group must "click" into place and lock so that it does not move in and out unless the "Press" button is depressed. It is possible that one of the above switches that signals the motor to start is stuck, even if the red light is out, and not allowing the motor to turn on. I don't see the reason why your brew group was stuck to begin with. How did that happen?
Nov 19, 2011 | Saeco Vienna De Luxe Espresso Machine
Saeco Giro II Red Light stays on, even after removing watertank, dredge drawer and brewing unit, and replacing. Red light does not flash after removing dredge and brew unit.
Had the same problem, if you used steam or hot water, make certain the steam knob on top is all the way back in the close position, if not the red exclamation sign will stay lit.
Dec 12, 2010 | Saeco Odea Giro Espresso Maker -...
A red light is on.
Hi I think it is the brew unit if I remember right. Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit
Feb 18, 2010 | Saeco Magic De Luxe Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
How do I pre brew
I got one of these for xmas, and I was able to program the pre-brew option.
First, turn off the machine.
On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
Kathy
Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
Saeco italia has front red light explanation
This red light is to indicate if the water tank needs filling, if the bean hopper needs filling, or if the brew unit is not in the unit (after cleaning) or not in the correct position.
Dec 28, 2008 | Saeco Easy Espresso Machine
Red light goes solid during brew
I would think its the watercounter that is broken, sry.
Jun 24, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Saeco Easy Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
