Damn menu keeps popping up and i can't stop it!! Very frustrating!!!
I've checked several different sites and they say the part is no longer available.
Help!!!
Comments:
Jun 21, 2009
- Is is a PITA to remove the back panel? Is it just a matter of removing the screws? Is the back of the front panel easily accessible once i get the back off?
Any info anyone can provide will be greatly appreciated!!
thanx in advance!
Jun 23, 2009
- OK, got the tray out, but i have nothing to de-solder the switch. Can i just take it out i.e. carefully break it off the board?
Jun 23, 2009
- cut the legs, fired everything back up and the damn menu still keeps popping up!!! I dont know what else to do!!
what else can i try????
Jun 29, 2009
- YOu mean the serial# of the TV? How much of a PITA is reaplcing the switch? Since i removed the other switch, i would think the problem is something deeper than the switch.
Jul 02, 2009
- Thanx for the help, but i'm guessing this would involve soldered the new switches in correct? I think i may just buy a new TV and be done with it.
Again, thanx for yur help!!
I will see what I can find. I do have a solution though. Unsolder the switch and if you have to get into the menue use the remote control. The set will work fine without the switch. It is unbelievable that these switches are nla but is does happen and way too often. If I am able to come up with something I will let you know if you kick back a response.
Hope this helps,
Skyassoc
Comments:
Jun 22, 2009
- The back come off pretty easy removing approx 10 screws. Once the back is off, pull the chassi out, ( there may be two screws toward the back tray that hold the chassi, two screws hold the front panel board in place, once removed it's all down hill from there. Remove switch, and reassemble.
Jun 23, 2009
- If you can cut the legs with a pair of wire cutters do it.
Jun 24, 2009
- I have good news, I found that the switch you were looking for has had two succeeding part numbers. The last being 23355507. And I have comfirmed it is available. You can obtain it through Encompass Elect. at 800-638-3328.
Hope you can finally get this thing fixed up.
Skyassoc
Jun 25, 2009
- Let me have the serial #and I will see what I can find out.
Jun 30, 2009
- I do have contacts but they cannot help me without Serial # and Model # information off the back of the set. One last piece of information I need is as follows. Turn the set on and unplug the AC cord. Then disconnect the plug connector for the front panel switch board from the main board. Plug the set back on and see if the menu pops up. Let me know what you find.
Jul 02, 2009
- I wanted to give you a update. Your problem is a switch on that board. It does not have to be the Menu button obviousely. But depending on which switch and how leakey it is can determin what on-screen display shows up. You must replace all the switches to fix the problem per inside info I got from Tosh. Tech Dept.
The part #'s I gave you should do the job.
I hope this will put this one to bed.
Skyassoc
how hard is to fix the remote control eye on the tv ?.I can't turn the tv on with a remote...
(More)
how hard is to fix the remote control eye on the tv ?.I can't turn the tv on with a remote anymore.yes the remote works on my other toshiba tv's
This WAS happening imtermittently, 'til NOW. I've replaced the remote and changed the batteries, and...
(More)
This WAS happening imtermittently, 'til NOW. I've replaced the remote and changed the batteries, and "most" of the time it performed OK, for the first week, affter I replaced the remote (w/new batteries). I can perform all of the functions via the front TV panel, but NOT with the remote. I went to the TOSHIBA web-site support, and "it" asked me: "Is the remote reset procedure accurate?" I cannot find anyplace in the manual "where" the remote 'reset procedure' and it's 'accuracy' is mentioned/explained. 'Might be my problem? 'HOPE SO! HELP!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
