Question about Jazz Tablets & eReaders
Where do i insert micro sd card in my ultratab
Where do I insert the micro SD card
5 Suggested Answers
SOURCE: I've inserted an SD card
thats simple when inserted you will see a popup that pop up is your new device if you can not see it than doubleclick on computer there u will see the new device the sd card just doubleclick on it and it will open
Posted on Jan 01, 2009
  • 679 Answers
SOURCE: Hi, 1. How to transfer/copy bootable XP files
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Posted on Jan 27, 2011
SOURCE: micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Posted on Nov 04, 2012
mileso
  • 3320 Answers
SOURCE: have a dragon touch y88, running android 4.1 jellybean that won't write to sd card. It will recognize the Micro SD all day long, just can't save anything to the card.
Was the SD card used by another computer/camera/device? You may have to format it Use Fat32
Posted on Apr 03, 2014
How do I transfer pitchers and video from my next book 8 coudcor tablet to my pixplus micro SD 32gb card l am new to all of this?
You need to download a file manager on the tablet insert the sd card in the tablet and use file manager to copy files from tablet to sd card hope this helps
Jan 17, 2018 | Tablets & eReaders
How do i load photos from sd card to samsung sm-t560 tablet
Insert sd card into tablet if it is a micro sd. If its a full size sd card you need to transfer files either to google cloud or other sharable app and transfer them that way... Like picassa app.
Apr 12, 2017 | Samsung Tablets & eReaders
My pad says the internal storage is almost used up...I inserted an sd card, but not sure how to get the tablet to read it so that I'm able to install more apps and games.
Good afternoon Linda!
You can view your manual here
RCA RCT6077W2 Manuals . If you go to page 10
RCA RCT6077W2 User Manual Micro usb Headphone Micro Sd it notes a couple of important caveats on the card:
  1. You can use MicroSD or MicroSDHC type cards
  2. Size limit of 32GB
  3. You are warned never to insert or remove the MicroSD card in 'On' mode (i.e. only insert/remove the card when the tablet is off)
Aside from that, it looks like things should work. To be sure on what is the root of the issue, you can:
  1. Insert your card into another device to verify that it works
  2. Format or Re-Format the card - the SD Card association has a formatting app here:
https://www.sdcard.org/downloads/formatter_4
  • Make sure the card is legit. If it was purchased, for instance, off of Ebay, or other not-so-top-tier online store, as likely as not it's a fake made in China, likely with guts from manufacturing rejects. You might, for instance, get a card marked 32Gb that actually has a 2Gb chip in it with a hacked controller that says it's 32Gb. It'll seem to work OK for a few files, and at some point will just write your files into no-where. SD Insight, a free checker app for Android phones can be picked up here
SD Insight Confirm your micro SD card authenticity instantly amongst many options.
Hoping this helps!
D
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
Make more space on my tablet
Buy and insert a memory card, check which size your tablet uses, possible a micro SD card.
http://www.howtogeek.com/189897/how-to-buy-an-sd-card-speed-classes-sizes-and-capacities-explained/
Note you can't do this for iPads.
Jan 18, 2015 | Tablets & eReaders
Insert micro sd card
It only fits into the slot one way. If it doesn't slide in smoothly, don't force it; try turning it around, or inserting it face down--one orientation will work.
Aug 11, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Trouble moving items from tablet to micro sd card
ES explorer is a great way to control your tablet. It is available on the Google Store, if you tablet allows you to access it. I rooted my Coby and found that the best solution.
Nov 18, 2013 | Ematic eGlide XL2 10.1 Inch Android Tablet
How do I insert the micro sd card into the Nextbook Premium
Good question. And before you brake anything, take a good look at the cover in the back for the SD card.... It is that square port next to the rear webcam. It is hinged at your right-hand side looking at your tablet from the back. Gently pull with your finger nail towards you putting the force to the left side that is where it opens like the port in a telephone. The other side knee it from getting lost and it should close thought even with the micro card inserted.
Jun 14, 2013 | Tablets & eReaders
HOW TO INSTALL A SD CARD INTO AN ONIX 7 INCH TABLET
NO NEED to install. Just insert the micro SD card to the card slot. That is it.
When you connect the tablet to your pc, the microSD card will appear as a drive letter on the window explorer. Very easy to use.
Dec 27, 2012 | Tablets & eReaders
Tablets & eReaders Logo
52 people viewed this question
Top Jazz Tablets & eReaders Experts
Are you a Jazz Tablet and eReader Expert? Answer questions, earn points and help others
