Question about HEWLETT-PACKARD HP G62 Notebook
Boot drive missing check cable - HEWLETT-PACKARD HP G62 Notebook
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Try HP recovery manager by pressing F11 key as soon as you power on the laptop.
Posted on Aug 19, 2015
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
How do i fix it?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 02, 2012 | E-Machines eMachines Desktop PC
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
Can get into Bios, BUT it won't reckenize the HD or CD. What am I missing. Its an Intel E210882 Motherbord, If I add an A Drive it will boot to it, but shows no HD or CD Drives ??
check your master slave configuration on the back of each drive. some hard drives prefer cable select but i never trust cable select to resolve conflicts with a differant manfactures hardware on the same cable.
Jun 11, 2010 | Intel Motherboard
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
HP Omnibook xe4500 on boot up says PXE-E61 Cable missing; Operating System Not Found. Wha do i do?
hi,
Selecting and un-selecting drives in BIOS can be a tricky process...let's try this: a) Step 1: go into BIOS, select F9 ( restore defaults) then F10 (save and exit). Re-boot. b) Step 2: back into BIOS, go into "startup" then into "boot" and choose "diagnostics". F10 to save and exit. Re-boot. You should be able to see both your drives (DVD and HDD) while "diagnostics" runs its course during boot. If you have a drive missing, there's your problem. If you don't have a drive missing, back to the previous idea: press F12, choose to boot from CD-ROM and see what happens this time around. Good luck and let us know. Install a fresh copy of windows xp. Thank you.........
Sep 14, 2008 | Computers & Internet
HEWLETT-PACKARD HP G62 Notebook Logo
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
