Question about Toshiba SD-2800 DVD Player
Tray open in 3 or 4 steps not one smooth movement
Then gives a disk error after closing
Open tray error
try to help it by lightly pushing it, cd tray gear tend to become unstable if not been use for a long time
Feb 03, 2014 | Bravo Computers & Internet
How do I fix the xbox360 open disk error I replaced the eye and I still keep getting the error Please help!!!!
I've experienced this problem too. these following steps helped me to solve it: 1: blow air in the xbox while the tray is open to remove dust. 2: put disc in tray and open and close it like 5 times. 3: You probably heard this before, clean the disc;) 4: Maybe sounds weird, knock on the xbox while its reading the disc. Hope this helps u
Sep 21, 2013 | Video Game Consoles & Games
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I take 7 or seven time putting the disk in and out before it reads a disk has happen since the first day i had it.
tip:read thease steps before startting
step 1:make sure there is no game in the console.
step 2:turn off your console.
step 3:take off the HDD from the top of your 360.
step 4:turn on your console.
step 5:make sure your disc tray is open.
step 6:put the HDD back on.
step 7:whilst the screen is black put game in tray and close the tray.
step 8:repeat thease steps until the game works
(it should take about 2 trys)
Jan 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
Hello, Brittany.
Give this a try (from HP Support):
Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
Step One: Check the paper and reload the original
The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
2. Make sure that the ADF tray contains no photo paper or carbon paper.
3. Make sure the paper in the ADF tray meets the following criteria:
* No curls, folds, creases, or tears
* No staples or clips attached
NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
* If still a problem, go to the next step.
Step Two: Open and close the ADF cover
NOTE: Remove all originals from the ADF tray before you open the ADF cover.
1. Open the ADF cover, and then close it again.
2. Press the OK button.
Follow these steps to turn the product off and then on again.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn on the product.
Hope this helps.
Feb 26, 2010 | HP Office Equipment & Supplies
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
Nov 01, 2008 | Panasonic SC-HT740 System
Region Settings
Turn Player On
Open The Disk Tray (Leave Open)
On Remote Control Press Stop
On Remote Control Press 1.3.6.9 and 0 (Zero)
Close Disk Tray
Power Off
or
Turn Player On
On Remote Control Press Clear
Close Disk Tray
Power Off
Jun 28, 2008 | Disney DTD1363-CAR 13" TV/DVD
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Xbox 360 open tray error
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Mar 25, 2008 | Microsoft Xbox 360 Console
Toshiba SD-2800 DVD Player Logo
14 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
