Question about HEALTHRIDER S300i Treadmill Motor Control Board 14470
Healthrider s300i lubrication
outfield502
  • 79 Answers
SOURCE: Treadmill turns on but none
just change the keypad
Posted on Sep 15, 2010
chiplevel
  • 656 Answers
SOURCE: Healthrider S300i Have 120V to AC1 & AC2 on
Make sure you have power in the wall outlet by plugging in a lamp, etc. into the same outlet the treadmill is plugged into to test. Plug it in the exact same receptacle. Sometimes in an outlet one receptacle will work and the other won't.
Make sure any breakers are fuses that may have tripped or blown have been reset or replaced.. Use the same type of fuse. Changing the value of the fuse can be dangerous or cause a fire.
Make sure the power switch is turned on and the safety key is inserted into the console if you have a safety key.
Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
Test for a motor control failure. Typically if you have a failure, the treadmill will continue to turn on and operate normally until you try to input speed. If the treadmill operates on what we call a closed-loop system, it will give you some type of error message. If it operates on an open-loop system, the computer will run normally but the motor will not turn.
If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good.
The motor can be tested by using a simple DC cordless drill or lantern battery. MAKE SURE TO USE A DC POWER SOURCE...DO NOT USE AN AC POWER SOURCE OR YOU CAN RUIN THE MOTOR.
Posted on Nov 01, 2010
Andriod Man
  • 271 Answers
SOURCE: I have a HealthRider S300i
you can try to rent a set at AutoZone. when you return it they will give your money back. try standard and metric. depending on manufacturer of treadmill.
Posted on Feb 09, 2011
ercupa190
  • 12223 Answers
SOURCE: my healthrider s300i softstrider treadmill
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Healthrider Softstrider
1) you have 3 problems: mechanical+ electrical + electronic.
2) adjust the tensions from deck bel + drive belt motor
3)test the main motor without load and see what happen.
4)test the main motor board and see what happen.
see block diagram
Controller what is the voltages output on a healthrider s300i
the voltage controller is the same for input voltage terminal of the motor .
test the input voltage terminal motor, if there ARE not the motor is faulty.Read my personal TIPS motor
2) test the output voltage control board, if there ARE not the control board is faulty
God bless you
Oct 21, 2013 | HEALTHRIDER S300i Treadmill Motor Control...
Where can I buy the motor control board for the spirit treadmill z-500?
you can buy in fixya.com
www.fitnessrepairparts.com
www.gymparts.com
www.treadmilldoctor.com
sincerely
Dec 13, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Healthrider will turn on and is in demo mode. will not do anything else.
1) IF THE MACHINE ONLY RUN IN DEMO MODE, TRY TO RUN IN NORMAL POSITION.
2)PUSH AND HOLD ON THE STOP BUTTON BY 5 SECONDS.
3) IF THE PROBLEM PERSIST, TRY TO TIGHT THE FLEXIBLE CORD FROM KEY PANEL VS DISPLAY BOARD.
4)TIGHT THE DISPLAY BOARD VS LOWE BOARD(MAIN MOTOR BOARD)
5) IF THE PROBLEM PERSIST THE MAIN MOTOR CONTROLLER BOARD IS PROBABLY FAULTY.
6)bEFORE TEST THE MAIN MOTOR.
SINCERELY.
12_13_2011_9_19_40_pm.gifSeethe block diagram
Jul 19, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I have a Healthrider Softstrider s300i treadmill and it will shut off with no warning after 35 min or so. I take out the safety key, reinsert it after a few min and it will go again.
see block diagram
Jun 27, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I have a HealthRider S300i treadmill, but unfortunately, I don't have the included allen wrench. So far I've been unable to figure out what size allen wrench I need. Any idea?
Feb 09, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
HEALTHRIDER S300i Treadmill Motor Control Board  14470 Logo
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
