Question about Garden
I need price of chainsaw chain sprocket. - Garden
    Habit-Forming:
  • 40 Answers
Go to ereplacements.com
Posted on Jun 18, 2014
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
steve_lima
  • 181 Answers
SOURCE: husqvarna 345 chainsaw chain doesn't move freely and heats up
has the chain ever came off the saw?and i'm going to assume that it is the correct chain for the saw...reason i ask about the chain comming off the saw is that when it does the driver have a tendency to become nicked and will heat up the clutch because the saw is trying to drive the chain links through the chain slot.also you need to look at the drive sprocket to see if there is any wear on the teeth....also over tighting the chain will cause the clutch to heat up.
Posted on Feb 24, 2009
steve_lima
  • 181 Answers
SOURCE: I want to replace the drive sprocket on my Jonsered 451E chainsaw. I found a replacement sprocket, but don't have a manual to guide me through the process of removal. How do I keep the driveshaft from
the threads are left hand.i my self use a small butterfly air rachet to remove the nut. it spins fast enough to remove the nut.
Posted on May 12, 2009
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
dontbother10
  • 2220 Answers
SOURCE: repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Posted on Nov 10, 2009
How do i unlock brake on a Poulan wildthing 2375 chainsaw
First, stop your engine. Check to make sure that the chain brake isn't engaged. The chain brake can activate automatically by a sudden movement or impact. You can disengage the chain brake by pulling the chain brake hand guard back against the front handle and releasing slowly. If the chain brake is disengaged and the chain does not turn; turn off the saw, then check the drive links on the chain, the bar groove and the sprocket nose on the bar. A burr on the drive links will bind the chain in the bar. If the bar has been pinched, the chain will not pass freely through the groove. If a sliver of wood has gotten into the sprocket nose, it will not turn at all. Also, look at the drive sprocket on the saw itself to see if it has a groove worn into it. A drive sprocket with a groove worn into it will damage the chain.
Sep 12, 2016 | Poulan 2375 Wildthing Chainsaw Gas / Fuel...
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Are you supposed to lubricate the bars?
If there is a little hole at the top of the chain bar sprocket--this is where you lubricate the sprocket on your bar--if you don't have the little hole by the sprocket then your bar is sealed and dont need to lube the sprocket--but make sure you have oil in your chainsaw's oil tank--that lubes the bar--chain oil is a must--dont use a chainsaw without it--unless you like to replace your chain and bar on a regular basis..
hope this helps!
Sep 18, 2015 | Garden
Why doe my sprocket on Husqvarna 455 keep tearing up the drive part of he chain
Are you sure the pitch of the chain is the same as the sprocket, ie if you are running a 3/8 pitch chain you need a 3/8 sprocket, if this is correct then you need to address your chain tention and sharpening.
Aug 18, 2013 | Husqvarna Chain Saw 20" Bar
Friction ring assembly of remington model eleven
Examine the chain saw to verify that the chain is still attached to the sprocket. If any part of the chain is not on the sprocket the chainsaw will not cut correctly.
Check the tension of the chain. If the lower part of the chain drops away from the guide bar, you will need to increase the tension. Remove the shield on the side case and loosen the nuts on the guide bar with the wrench. Pull the guide bar to increase tension on the chain and then tighten the nuts.
Clean the chain if it appears dirty. A dirty chain will not cut as efficiently as a clean chain. Loosen the tension on the chain and then take the chain off of the guide bar. Soak the chain in a solvent, such as mineral spirits.
Examine the sprocket on the chain saw. If it appears worn, bent or out of pitch, a new sprocket will be needed.
Examine the chain to see if there are any damaged drive links. Replace the chain if too many of the drive links are damaged because the sprocket will not turn the chain.
Examine the guide bar to see if it appears crooked or is out of alignment. Remove the nuts from the guide bar by following Step 2. Take off the old guide bar and then install a new one.
Sharpen the chain if it looks shiny. The shine on the chain indicates that the steel that is underneath the chrome plating on the chain has worn away. Use a round metal file on the steel until there is a thin overhang of chrome over the cutting edge of the chain. This will restore the cutting edge
Read more: How to Troubleshoot a Chainsaw Chain ' eHow.com http://www.ehow.com/how_6317552_troubleshoot-chainsaw-chain.html#ixzz1fLUkDPOc
hope it helps
Dec 02, 2011 | Remington Garden
I want to run a 3/8 pitch 0n my 028 do i need to
The following is copied from the Oregon FAQ "What is pitch".
Chain pitch is the distance between any three consecutive rivets divided by two. Pitch defines the size of the chain. OREGON® chain is made in several pitches - 1/4" is the smallest, 3/8" is the most popular. Other parts of the cutting elements are pitch-related. The drive sprocket must be the same pitch as the chain, and so must the nose sprocket in sprocket-nose bars.
An illustration and the original question is here: http://www.oregonchain.com/pro/service/faq.htm
If the result from an existing chain is 3/8"s or 0.375" then you need not replace the sprocket. If the result is different then the drive sprocket and bar nose if sprocketed must be changed. Chain gauge must also match to prevent problems.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 03, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Husqvarna chainsa;starts but chain sprocket doesnt
1) Chain brake is on. Pull the handle back towards the operator
2) Chain is too tight on bar
3) Debris caught inbetween bar and chain
4) Sprocket teeth are worn out
Nov 26, 2009 | Husqvarna Garden
Repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
Results follow:
Lou
Nov 10, 2009 | Remington Garden
Need to clean out chain saw sprocket area
Hi dorothy. Here is the link to give you a free manual that will give you all of the info u need.
http://www.remingtonchainsaw.com/chainsaw.html
Mar 14, 2009 | Remington Electric Chain Saw
Poulan 2600 chainsaw
Sounds like the chain brake may be causing it.
Oct 15, 2008 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
