Question about Vehicle Parts & Accessories
Leaking vehicle door seals - Vehicle Parts & Accessories
    Master:
  • 710 Answers
Replace seals, check door futment.
Posted on Sep 01, 2014
How to stop water from coming in the passenger floor board
That depends upon the cause of the water. There are a few possibilities, depending upon the vehicle. See this list and use what applies as a way to narrow down the source.
1. Rust hole in floorboard. Only way to fix is to repair hole.
2. Leaking door seal on passenger side. Locate and repair leaking seal.
3. Leaking sun/moon roof. Some vehicles that have these run their drain lines down the passenger side door pillar and down thru the floor pan. Sometimes the hose shrinks with age or breaks and allow water to get on to the floor. Remove the passenger side kick panel and inspect and repair as needed.
4. Leaking heater core. Feel and smell the water. If it smells like antifreeze or has an oily feel, it may be coolant leaking from the heater core. Of course there should be a loss of coolant associated with this problem. Here the only solution is to bypass or replace the heater core.
5. Leaking windshield seal. Most car windshields today are glued into place. These glue joints can break loose and allow water to leak. Also, rust can form around the windshield seal and cause rust holes that can leak. Lastly, extremely high-powered car stereo systems that pump mega-bass can cause overpressure inside the vehicle that can cause the seal of the glass to separate.
Jan 31, 2016 | Cars & Trucks
Lots of rain water leaking into front passenger foot rest.
Are you certain it is rain water? It could be condensation from the A/C coil that fails to drain out of the drain pan, or possibly coolant from a leaking heater core. If you are certain it is rain water, depending upon the age of the vehicle, and possibly some other things, here are the possible options:
  1. Leaking door gasket.
  2. Leaking windshield seal due to rust
  3. Leaking windshield seal due to improper installation
  4. Leaking windshield seal due to acoustic (sound) over pressure (if you have extreme sound system with heavy bass)
  5. If you have a sunroof, if the drain hose comes down the passenger side door column, it could be leaking into the passenger compartment rather than drain through the floor pan.
Oct 29, 2015 | Cars & Trucks
1997. How do I adjust the rear door to stop it from leaking?
leaks can be caused by many things
bent door
bad gasket on door
bad window seal.
first is to discover that.
adjusting is not trivial due to the very tight bolts there.
takes special tools to do that. (impact gun and special bits)
some times just making the strike plate , moved inward will stop a leak, it too , has very tight screws.
The FSM book covers this topic, under BODY chapter.
Oct 04, 2015 | Isuzu Trooper Cars & Trucks
Hi I have a 2005 Honda Odyssey and have found water leaking in the car on the drivers side and passenger (not as bad) also in the back behind driver, all seals are good mechanic checked it all looked good,...
I would have all your weather stripping checked around your windows and doors (rubber pieces around windows and doors). If it is not pushed up in the slot like its supposed to be that could cause a leak. Hope this helps, James Booth. Please rate this. :)
May 20, 2011 | Honda Odyssey Cars & Trucks
WHY WOULD RAIN LEAK IN NEAR FRONT DOOR? ALL SEALS
Some leaks actually are from the windshield and it is contained by the trim so you can't see where it is leaking from. If it is the door seal look at the striker bolt to see if there is any abnormal wear. Make sure the striker bolt is aligned with the door striker. If you don't know how to check this run by your local body shop and ask them to check it for you. Sometimes if the keys have ever been locked in the vehicle people use door shims to hold the door open as to pick the lock. This is bad because it knocks the door out of alignment with the seals. Hope this helps.
Feb 06, 2010 | 2006 Jeep Liberty
Hi, rear footwell is filling up with water behind drivers seat. seems to be happening after heavy rain. Not sure if door seal problem or bung thing being clogged up under battery as some sites seem to...
It's probably coming from the sunroof drains being clogged.
Open the front door, look closely, you will see a rubber tube sticking out 1 inch. Cut off the tips so the tube is wide open.
Nov 16, 2009 | 2003 Volkswagen Passat
Water in Floorboard tailgate area
Gasket on the door has gone bad and needs to be replaced. It seems like the door gasket is not sealing properly and allowing water into your vehicle or you have a leak in the bottom of the vehicle that needs repairing. But that is more then likely not the problem
May 23, 2009 | 2000 Lexus LX470
Water is leaking in the back on the drivers side
You may have a bad door seal strip. Check the rubber seal that goes around the door frame on the body and make sure it's first in place correctly, and secondly not torn, ripped or damaged. also make sure your window seals are good too. Good Luck
Dec 14, 2008 | 1999 Ford Explorer
Back Door Leak
read your extended warranty book you will find it does not cover this problem the door should be able to be adjusted or moved to stop the leak i do it with a peice of paper between the door and the seal you should not be able to pull the paper out
try this it works Lindz
Aug 11, 2008 | 2002 Toyota Sequoia
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
