Question about Speed Queen SWT921 Top Load Washer
Washer start agitating with out filling water manually fill water and it will work and extract when finish then error code for drain comes up
Need to find the installation manual for error details
  • 177 Answers
SOURCE: SpeedQueen washer trouble
You could have a couple problems, it could be the timer, motor or Transmission.
Start by removing unplugging the washer,
Now remove the front panel, two 5/16" screws at the bottom of the front panel. the front panel will either drop off or you have to turn it up to remove it
In the front on the bottom is the motor, on the bottom of the motor is the belt. This belt drives the pulley on the bottom of the transmission. It should turn both directions. in one direction the transmission will ramp up and unlock the brakes letting the unit spin. The other direction the transmission will cause the agitator to turn back and forth. you may need two people one to watcht the agitator and one to turn the belt, Now if the transmission does not turn at all you have what is known as a locked transmission. This is a major expense. Look for a new machine.
If the machine does actually agitate and spin when you move the pulley it could be as simple as a motor or timer. Please let me know what you find and we can go further.
T
Posted on Jul 07, 2008
hattonhall
  • 349 Answers
SOURCE: THE TUB OF THE WASHER GETS REALLY LOW WHEN IS
All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
What is not normal is water not coming in.'
check following:
Water is turned on
Remove inlet hose and run water to see if it is blocked.
Clean the inlet filters.
If you hear a buzz but no water goes in the inlet valve needs replacing.
If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
Then only turn on the Cold Tap.
This will allow you to fill the machine and do a wash.
Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
Have yu got all that?
Posted on Oct 25, 2009
charleshucke
  • 1114 Answers
SOURCE: Speed Queen AWS51NW Top load Washer. Fills with
You will need to replace the cycle timer, or control board to resolve this issue.
Posted on Mar 21, 2011
  • 6277 Answers
SOURCE: The washer does not fill
This is symptomatic of a malfunctioning water control valve- the hot water one in your case. Sorry but it needs replacing and a service call to confirm that it is not something else like the control board ;-0(
Good luck,
John C
Posted on Mar 22, 2011
g_reynolds80
SOURCE: I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Posted on Jan 29, 2012
My fisher and faykel washer model wa37t26gw2 does not fill, and will not drain. diagnostic says plugged drain hose, but it is clear from pump to diverter
Your question does not make sense. You say it does not fill but then you say it will agitate. How can it agitate if no water has filled? Does it beep and give an error code/ If so what is the error?
Jul 23, 2016 | Fisher and Paykel Washing Machines
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Fills with water, not agitating
They probably dropped it a good one and jarred the computer. The bump bump bump down the steps into the basement. Hmmm rain on electrical components , if they used it right away and didn't give it a chance to dry out, yeah that might cause shorting across the board. The mechanisms are electronic now and not mechanical like the good old days (My uncle worked for Kelvinator and had old pieces laying around). What about overloading it? Are they overloading it? They've lifted up the cover and peeked at it and saw that it's not agitating? Are they incompetent? So many variables.
Jul 09, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Speed Queen SWT921 Top Load Washer Logo
11 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
