Question about LG LSC27925SW 27 cu.ft. Side-by-Side Refrigerator with Ice and Water Dispenser in Smooth White LSC27925SW
LG LSC27925SW refrigerator keeps beeping 3 times every 30 seconds. Doors are closed. What can cause this?
SOURCE: Refrigerator is beeping intermittantly with door closed
Hey, Catriver -thank you so much! I will try your suggestion with the piece of plastic first thing, will post back rightaway. Len
Posted on Oct 24, 2006
SOURCE: My refrigerator is peeping every 2-3 minutes,
I called the repair department from the dealer where I bought the fridge from and they helped me.
thank you.
Posted on Apr 06, 2009
SOURCE: BEEPING NOISE
in the back of the fridge there is a panel. Remove the cover plate. Look for the buzzer and remove it. This will cancel the annoying beeping noise.
Posted on May 05, 2009
jeffbvegas1
  • 520 Answers
SOURCE: My refrigerator LRSC26925 LG
Im afraid you may be having control board problems ... board can be found on top of fridge under plate where power cord enters unit .If your unit is out of warranty that board can be obtained through andrewselectronics.com or contact LGUSA.com for any customer service or warranty information. Unfortunatley that board is quite expensive. Try unplugging the fridge and replugging it to reset and press diagnostic button on the board
Posted on Jun 27, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
How do I put my LG side by side refrigerator LSC27950ST in test mode? It is beeping every 30 seconds and the door is not open.
Theres a button to shut off door alarm. check to make sure doors are shut. if that doesnt work , is there any error codes showing?
Jan 25, 2017 | LG Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Since hours I hear 3 short beeps - no open door alarm., No error code.
This model has trouble with ice building up behind the freezer doors preventing them from closing all the way. You may need to defrost.
Nov 05, 2015 | LG 24.7 cu. ft. French-Door Bottom-Freezer...
My dd lg refrigerator model GGL-478YSX4/2011 BEEPS EVEN WHEN DOORS PROPERLY CLOSED
Its telling u that the refrigerator setting should be lowered or raised. I keep the freezer setting on the highlighted setting and depending on the weather your refrigerator will beep when the setting is either to high or to low. If its hot and humid outside it probably raise one notch and if the outside temp has cooled then lower one notch. Just have to experiment. Good luck
Jun 12, 2015 | LG Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Continual beeping
Hi, welcome to Fixya A very common problem with those fridges actually. Check to make sure the door sensor`s are secure and contacting each other when the door is closed. You can do this by accessing one or both sides of the door sensors at the hinge assembly cover at the cabinet top. There should be sensor`s on either side which sense when the door is closed by "making" with magnets on the doors. They sometimes become loose from where they are held in place and therefore do not indicate the door is actually closed. That is the most likely cause. If this does indeed help you solve your issue please take a moment and rate it accordingly. If it doesn't solve the problem let me know and I'll try and assist you further. Thanks for visiting "fixya" today. good luck. macmarkus :)
May 16, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG Refridgerator LFC257060ST Keeps Beeping
Please check whether the doors are aliened properly to the body and if there is a small warp it could result in escaping of cooling resulting in poor cooling of both the freezer and the refrigerator chamber.
The magnetic gasket is the next reason for poor cooling. So please ensure that the gaskets are having magnet attached to the full length. Broken magnetic strip inside the gasket could also result in partial closing of the door leaving behind plenty of gap allowing the cooling to escape.
Just insert a visiting card between the gasket and the body and if you could do so then the gasket is not effective and requires replacement.
BEEPING NOISE
May 01, 2009 | LG Refrigerators
Door alarm keeps sounding even though doors aren't ajar
The problem is the doorswitch of the freezer door. The door 'bump' which has to push in the swich doesn't push it in far enough. You can try and hold the switch an dpush it in with your finger and see if the sound continues. You can try to adjust the door, but easier is to glue or tape something to the door 'bump' so it pushes the switch further in. Hope this was the issue.
Jan 04, 2008 | Refrigerators
LG LSC27925SW 27 cu.ft. Side-by-Side Refrigerator with Ice and Water Dispenser in Smooth White LSC27925SW Logo
41 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
