Question about Toaster Ovens
Constant beeping when plugging in the toaster oven all it does it beep
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Breville beeping too loud
The beeping sound is annoying and mostly unnecessary. Unfortunately it can't be turned off. The only way to "fix it" would be to remove or disable the Piezo buzzer. I tried doing this, but disassembling the oven to reach the pcb control board ,where the buzzer is located, is complicated. You can take the top cover off using a Philips screw drive. But reaching the pcb board is tedious. So I gave uP and reassemble it. If someone has a better idea or method , please share. This is a great oven except for the annoying beeping. Even my dogs are afraid because it is the same sound that my invisible fence has and they think that they are being warned.
Mar 28, 2013 | Breville BOV800XL 1800 Watts Toaster Oven...
Waring TCO650 toaster oven - how to turn off or down the beeping
I found it! In the manual that came with the toaster (and not the one online), I found the following instructions:
1. To turn the indicator beep OFF: Press both [TOAST] and [BAGEL] keys and hold for 5 seconds.
2. to turn the indicator beep ON: Repeat the above process.
Note - if you lose power or unplug the unit, the beep comes back, so keep these instructions handy. :)
Dec 01, 2012 | Waring Tco650 Professional Toaster Oven
How can I turn off the annoying "beep" on my Krups Toaster Oven?
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
Dec 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Fan works timer works but no heat
There is no fuse. Take back cover off and all bottom perimeter screws. Outside cover pulls off towards rear once you get all the ** little screws out. Chances are you will find burned connections on the heating elements poking out the sides of the heating chamber. Try cleaning these and squeeze them tighter before reconnecting. Good luck!
Oct 22, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
My toaster keeps beeping and comes up with an error message can you help
I just called Oster Service and the said to plug in the unit, hold the start button for 10 seconds and unplug the unit. My oven reset before I was able to try this, so let me know if this works for you.
Dec 08, 2007 | Oster 6235 Toaster Oven with Convection...
"Err"or message with beeping
Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
Toaster Ovens Logo
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
