Question about Toshiba (SD-R2412) for Satellite A10, A15, A40, A45, Tecra A1 Series (SDR2412) CD-RW/DVD-ROM (Combo) Burner
Dvd-ram controlers problems in regestry
  • 2,427 Answers
RUN a register cleaner or repair program
I use TUNE UP UTILITIES
Reinstall drivers
Posted on Dec 30, 2007
Hp pavilion starts up but only the 'hp loading' status. doesn't move beyond this point - just get hp logo and the circle 'loading' endlessly
this is a couple things . Your hard drive could be gone. Or your hard drive has been corrupt and cannot find the necessary files to start. Check to see if you can here the drive when you boot it up is it quiet it should be. if its missing files and corrupt you will need to try and reinstall the operating system.. Some things to try first is to reset your ram by removing it and re seating it sometimes ram will loose connection.
Mar 09, 2015 | HP Computers & Internet
Tip
How to speed up your windows computer(xp,vista,win7)
This has been a question of a million people that "How can i speed up my computer" so today I will share some small infos that will help you to speed up your windows based pc/notebook/laptop with a very small knowledge about your computer.
#Your computer has some beautiful tools built in to help you speed up your pc. The main reason that makes computers slow are basically less memory, running more service/programs at once and some Regestry error which occurs due to various software install and un-install. Regestry errors makes your computer works more and get less work done. so this is what you could do
#1.open run/search box from the start menu nad type in this" cleanmgr" delete/cleanup the files you want to remove/ you don't need. That will give you some extra space to work with.
#2.Download ccleaner which is free software reomended by various computer experts. install and run the software. It will also help you to cleanup some extra space. you can use the regestry option to check for some simple regestry error and fix those.
#3.Open ccleaner and go to "tools">>startup and change the programs you don't want to start when you start your computer for exmaple. skype,yahoo,fax/printer service etc. This will decrease your computers bootup time.
#4.from the start menu open the run/search box and type in "dfrgui". this will defragment your computer and fix some regestry error.
#5. Download any good regestry cleaner. I will recomend Regestry Mechanics a software made by pctool the same sompany makes the best anti spyware " Spyware doctor".It will help you to fix almost all the registry error.
Now restart your computer and you can feel the difference by your self. thank you!
on Mar 07, 2010 | Computers & Internet
The computer and the internet is slow, i cant do any thing because it stops, starts over and i dont know why
press win key+r
Type %temp%> Enter
Now you will delete all the temp file from temp.
Please download cccleaner from file hippo.com and cleane regestry and cleaner .
Follow the bellow download link.http://filehippo.com/download_ccleaner/
Hope this helps.
Jan 10, 2011 | Compaq Armada 1700 Notebook
How can i make my pc run faster and can i change the hard drive where i can start over it was giving to me by my friend and what ever he has on there i don't need
first of all download ccleaner
run and scan for unwanted files
download a regestry cleaner like regestry mechanic
do regestry scan and fix the errors.( ccleaner also has a regestry cleaning option but it is limited)
change your startup programs and uninstall programs you dont need.
let me know if you need more info
Mar 07, 2010 | Dell Inspiron 2200 Notebook
No valid drive/disk when dvd is inserted program tells me there's no valid drive or disc found?
say that the tsst corp cd/dvdw ts- l632d ata device
code 19 or 13 is corrupted or regestry is the problem.
Sep 20, 2009 | Intervideo WinDVD 5 for PC
Hresult 0x88980406. my game freezes and this comes up? any ideas
Hello my friend, this error refersto the regestry of your application games that signifies an error causing to overwrite malfunction of some of your module particularly the part of the program in your games. Its either this error occur because of machine failure particularly corrupted program while you are running this application or error in writing your regestry update in your OS while you are still running this application.  So i recommend that try to resboot your computer and try to run again the same application but before you are going to play vist the option then adjust the setting to it recommended or low settings. in that way, you can prevent the same error as you have experience. But if the application is not running and same problem occur then i suggest kindly reinstall it and then during the installation process make sure that it is carefully and successfully installed properly.
Hope this solution i post will able to help your problem. If you need more assistance just reply to this post.
Thank you
Jonas
Jul 09, 2009 | Microsoft Windows Vista Home Basic Edition...
Phillips dvd drive/cd burner does not burn cds
Might be the regestry, errors can accure throught the reg, nothing you did it just happens. Try this and see, "Start" "Run" type in "regedit" then ok in the left field click on the "+" next to Hkey_Local_Machine" + next to "System" + next to :CrurrentControlSet" + next to " Control" + next to "Class" then click on " {4D36E965-E325-11CE-BFC1-08002BE10317} " in the right fild click on "Upper Filters" then "delete" now "Lower Filters" then "Delete" restart pc. Hope this is helpfull.
Jun 22, 2009 | Computers & Internet
My system cannot find the dvd/cd-rm
check in my computer if theres a cd/dvd near with drive C: or D: etc...
if not there, you reboot the laptop and press F2 to bios setup and check the cd/dvd setting if detect,if not, hardware problem...if it is detecting and not showing in windows,theres a virus in the regestry,i think so..try to scan..if not come...format..finish
Jan 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Htc p3300 disable blocker
i rang customer services - its somewere in the regestry, i dont know where but you can access the regestry with total commander
Feb 22, 2008 | HTC P3300 Smartphone
Toshiba (SD-R2412) for Satellite A10, A15, A40, A45, Tecra A1 Series (SDR2412) CD-RW/DVD-ROM (Combo) Burner Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
