Question about Singer CG590 Mechanical Sewing Machine
The needle,keeps hitting the needle plate
The needle keeps hitting the needle plate
bargainbox
  • 1388 Answers
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Posted on Feb 10, 2008
Tally Girl
  • 1129 Answers
SOURCE: needle keeps hitting the plate
That sounds bad, simple thing to check: does it have a straight stitch needle plate on it that is causing this to happen when you use a zig zag stitch?
Or is the foot on it the right one for the machine? It certainly should not be breaking needles like that so something is either out of alignment, timing is out or some item has been incorrectly fitted.
Posted on Mar 29, 2011
SOURCE: singer xl150 needle breaking
it sounds like the machine is out of time, only a sewing machine repair shop has the tools to retime a machine
Posted on Jan 20, 2012
  • 20 Answers
SOURCE: needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Posted on Jan 27, 2012
SOURCE: The needle is hitting the foot
it sounds like the machine is out of time & needs to be serviced
Posted on Mar 17, 2012
My Viking opal 690Q needle is tapping plate underneath won't let me sew over loaded symbol keep coming on does the need re position it self can't sew need help.
If it's hitting the needle plate, try installing a new needle. If it is still hitting, then it needs adjustment. Take it for service.
Dec 18, 2016 | Sewing Machines
My needle keeps hitting the metal plate, and its a brand new needle. It seems like the alignment of my brand new machine is off. Basically, the needle keeps hitting the metal plate where the bobbin is, and...
Check whether the needle is installed correctly - maybe it's turned around from machines you are used to. Also verify that the needle plate is installed correctly, not upside down (may be possible on some machines). If the needle and plate are installed correctly, then something is out of line, and you're owed a free adjustment or repair from the manufacturer.
Feb 10, 2015 | Sewing Machines
I know how to attach my ruffler foot but my needle keeps hitting the plate .what do I need to adjust to keep the needle from hitting the foot
You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
Sep 13, 2014 | Sewing Machines
The right needle on my babylock keep breaking
Perhaps the needle is not fully pushed in or not tight in the holder or has the needle plate moved and the needle is now hitting it? A bent needle will break as it hits the plate but apart from that I cannot imagine what is causing this.
May 04, 2012 | Baby Lock Sewing Machines
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
My needle keeps hitting the throatplate, (I have broken 2). It was working fine. I don't know what I have done to cause this! e.
First, check the position of your needle.Machines with zigzag capability allow you to adjust the position of your needle left, right,or center. If your needle is not in the correct position, it may be hitting your needle plate. If that doesn't work,change your needle plate.
If you've been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
I hope this helps.
Mar 22, 2010 | Sewing Machines
My needle keeps hitting the plate and breaking. How do I fix this?
Take the needle plate off and see where it needle is connecting with the bobbin. The bobbin case may not be in place and this is what the needle is hitting.
Feb 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    Make sure it’s attached securely.
    A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
    Make sure it's securely in position.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits the plate
Remove your needle plate, clean around it, turn the handwheel to see if the hook will catch your thread(Like you are trying to bring up the bobbin thread). If it catches okay, put the plate back on and as you tighten the screw push the plate towards the rear of the machine. Reassemble everything, rethread , insert a bobbin and try it by turning the handwheel again. If it still hits, you need a service. If it doesn't, have fun!!
ssewman7
Jun 07, 2008 | Bernina Virtuosa 160
Singer CG590 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
