Question about Panasonic Lands Phones
Kx-tg2511al how to set up base - Panasonic Lands Phones
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Help with and manual for the KX-TG6441 answering base
Here ya go.
You need to make sure you have Adobe reader installed on you computer before going here. The full manual as if you just took it out of the box.
http://service.us.panasonic.com/OPERMANPDF/KXTG6431-MUL.PDF
Dec 28, 2011 | Panasonic KX TG6441 Phone
How to return product KX-TG9333T purchased Premium Store.com. Item is same as already have. Thought it would be an upgrade.
The hand set never worked since I bought it. All other hand sets work as well as the base. I would like you to send "free of charge" a replacement hand set as well as the base for the hand set Hand set which never worked has #OGBXBO61363 UNDER THE BATTERY COVER. wE TRYED REPLACING BATTERIES SWITCHING BASES ETC.
Oct 17, 2011 | Panasonic KX-TG9333T Trio Cordless Phone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
Got a new set of handsets but the base doesn't recognize them...
Hi - Are you sure you have followed the following procedure exactly?
Have the correct base units for these handsets which are:
KX-TG1032, KX-TG1033,
KX-TG1034, KX-TG1035
Are using NiMH batteries
That have been charged for at least seven hours
Have followed this procedure:
Good Luck,
Mikeywaf
Mar 31, 2011 | Panasonic KX-TGA101S Cordless Handset
WHAT IS THE FACTORY SUSPENSION SETTINGS ON A KX
I can give you reccomended Team Green setting for your weight, dirt bike setting are usually based on weight,
May 03, 2010 | 2003 kawasaki KX 125
Kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Nov 04, 2008 | Panasonic KX-TG1100 Cordless Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
Lands Phones Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
