Question about Sewing Machines
Can do a straight stitch, but cannot switch to zip zag or any other stitch
Pacesetter by Brother PC 3000. The Stitch selection keys do no work when touch a key. Seems like it is locked in straight stitch
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 1116 Answers
SOURCE: Old style 830... having trouble doing automatic stitches
Take the machine to an authorized Bernina dealer for service - make sure to fill out the service slip with any problems you are having.
Posted on Mar 05, 2010
  • 980 Answers
SOURCE: How do I access the triple zig zag stitch. I
If you can't get any particular pattern once you have selected it and set the stitch width it might be wise to take the top off and have a look at the nylon cam stack to see if there is a split in it.
Posted on Jun 15, 2010
  • 980 Answers
SOURCE: I have a brother pacesetter 607 model. It used to
Simple things first, check the needle to make sure it is perfect, if you can select all the patterns and the needle moves from side to side but does not pick up the thread then it could be a timing issue and you can email me for attachment of instructions, if the needle is not moving side to side when you select a pattern then it may well be a split camstack.
drivewithken@blueyonder.co.uk
Posted on Jul 05, 2010
Tally Girl
  • 1125 Answers
SOURCE: The machine is not stitching
If the bobbin thread is coming up to the top, then the thread is not under tension correctly. I think that this is a top loading bobbin so the bobbin will go into the bobbin holder, then you pull the thread back and press it into a tension device - should hear it click into tension. Now pull the thread back towards you and it should not come out of the tension. The bobbin should turn anticlockwise as the thread is pulled from it.
These bobbin holders usually will have a small adjustment dial on them and it should have the standard setting marked in red. It is very unusual that you would need to change this but check that it hasn't been messed with perhaps. If you have the machine manual check where they say the dial should be set. More likely that the thread is just not into tension fully or at all.
The manual may give you other troubleshooting tips too.
A good resouce is www.sewing.about.com for general machine tips, cleaning and threading issues.
Hope this helps.
Posted on Apr 11, 2011
How do I get my brothers pacesetter XL703 to come off the stretch material stitch
Marilyn, get your manual and read... That is a simple stitch selection change.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 09, 2014 | Brother Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Stitch selection does not work
The switch could be bad or the mechanics that physically move the needle for the zig zag could be broken/worn. Hope you get it fixed soon!
Apr 04, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
How to sew Shell Tuck Stitch.
I can't find an image clear enough to actually see the stitch selection on the front of this machine.
Does it have a stitch that looks like three or 4 straight stitches, then one zig zag, then more straight stitches? This is the stitch you want to select to do a shell tuck.
Then hold your fabric with right side up and turn edge under about 8mm and seam along the edge using this stich so that the zig zag stitch goes over the folded edge each time to the right. This should pull in the folded edge a little giving a scalloped edge.
Just do a couple of trials to work out the best position for the folded edge on the needle plate to get the effect right, probably just the edge of the normal straight stitch but it varies for each machine. If your machine does this stitch with a variable adjustment on the width of the zig zag part, then you could finesse it with this too.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
