Question about Apple iBook G4 Mac Notebook
Startup is all jacked up:(:(
When I start up my computer the typical blue screen shows up with the apple. And then shortly after, a circle shows up with a slash going through. After about five minutes the computer turns off. I also cannot eject the disk that is in there to put in the software install disk.
  • 1 more comment
  • greendaygtr Jun 18, 2009
    I looked for that, but couldn't find it. Also another thing that concerns me is that This happened after I reinstalled the hardware... And the disk that is inside is the 2nd installation disc.
    Ok, so I got the disc out but the circle with the slash is still there.
    So, as an update... I got the cd out, but the circle with the slash still shows up
    President:
  • 1,383 Answers
First when you power up the computer press F8 key then enter in enable vga mode then change screen resolution to 1024*768 .
Also reset your bios settings .
When you power up press "del" or F2
then you can see bios.
Posted on Jun 18, 2009
  • 87 Answers
The circle-slash means the Mac couldn't find BootX on the startup volume. Which means you either have a bad boot sector on your harddrive or the computer is trying to boot from whatever disk is in the drive and not able to.
There's usually a manual override to eject discs, like a little hole you put a stright pin or tiny nail through and push a lever to release the tray and get a bad disc out.
How to get iPad to start up? I push both buttons until the Apple appears and that is as far as it goes. The Apple is still showing on the screen. What do I do next?
Hi Anon !
If your device gets stuck during startup When starting up, you might see the Apple logo or a red or blue screen for a long time, or your device might restart again. Try these steps:
  1. Make sure that you have iTunes 12 or Later on your computer.
  2. Put your device in recovery mode.
  3. When you get the option to restore or update, select Update. This will reinstall iOS without erasing your data.
  4. If you still need help after trying the steps above, contact Apple Support.
Feb 25, 2015 | Apple iPad Tablets & eReaders
Apple laptop continues circling doesn't startup
looking for bootable drive. Try restting pram, try starting with os disc and holding down letter C go to drive select in utilities. select drive you want it to beet from.
Feb 17, 2014 | Apple Computers & Internet
My computer is not coming on and when it does it go's throw it shows a blue screen then it cuts off and starts back up n does it all over again.
This is typically caused by Windows startup files being damaged, or a incompatible drivers during startup.
See if you can get into "Safe Mode" and then run a System Restore to a date previous to when the issue started to occur.
Aug 24, 2011 | Compaq Computers & Internet
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
Computer won't start up correctly
Considering you have tried the Safe Boot mode to correct this, try to resolve this from the hardware side:
Procedure #1:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the star tup sound for the third time.
• Release the keys and allow the Macbook to start up.
If the iMac still does not start up to your Desktop correctly, go on to the next procedure:
Procedure # 2
-PMU RESET-
The Power Manager is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect all the connections going into the Mac except for the Power cord.
• Once all connections have been disconnected, remove the power cord from the iMac.
• Wait 1 minute.
• Reconnect the keyboard, mouse and power cord back into the computer.
• Press the Power button to restart the iMac computer.
• Observe if it starts up to the main desktop this time.
If it does not however, you may have an issue with your current Mac OS X directory or the issue could be hardware related.
Here is a comprehensive reference for you regarding Additional Troubleshooting for Blue, Gray screen issues and more, that you can also review:
Apple Support Link:
Startup Issues for Macs
If all else fails, you may need to visit your local Apple retail store Genius bar or local Apple-authorized service center in order to have your iMac at least diagnosed to find out what the core issue is.
Regards,
-Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
Computer won't show start up screen, only shows different colors ie. green, then pink, blue... i took out the battery and started it without the battery and got the same results.
First you need to reset the PRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Next you need to reset the PMU (power management unit). This will depend on the model of your iBook so follow the instructions on Apples page:
http://support.apple.com/kb/HT1431#faq6
Hope this gets you going again
All the best
Sean
PiDigital
Jan 17, 2009 | Apple iBook G4 Mac Notebook
My Mac laptop won't start
1. try single-user mode (hold down Cmd-S during startup tone and sequence). this should take you to a command-line screen where you can run the suggested fsck command: /sbin/fsck -fy (at the command prompt).
2. go here to see complete startup procedure in situations like this: http://support.apple.com/kb/TS1417.
3. if that doesn't work, it sometimes helps to start the computer in target mode while attached to another computer via Firewire (hold down the "T" key while starting up). then you can navigate through your ~/Library/Preferences and find the most recently modified ones and pull those into a test folder on your hard drive somewhere (just create a new folder to hold them temporarily). then restart as normal. sometimes just yanking the most recently modified preference files (.plist files) works.
Sep 07, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple iBook G4 Mac Notebook Logo
99 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
