Question about Craftsman Garden
Starter won't engage
I have a 20Hp Model 917.28812. I replaced the starter and the Solenoid but the starter will spin but will not engage to start the tractor.
  • 16 Answers
SOURCE: Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Posted on Nov 11, 2008
  • 376 Answers
SOURCE: 14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
Posted on May 23, 2009
  • 218 Answers
SOURCE: 1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Posted on Jun 30, 2009
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
  • 302 Answers
SOURCE: lawn tractor, engine model 42A707, starter spins
I had this same problem with a twin cylinder B & S engine and was able to get just the gear drive replaced without replacing the whole starter. Hope this helps you
Posted on Nov 10, 2009
Starter on my 91 ford ranger 4 wheel drive starts my pickup a couple time then it just spins have changed it 3 times now
Assuming the starter motor spins but doesn't engage to turn engine over to start you could have a bad starter drive which is part of the starter assembly or possibly damaged/missing teeth on flywheel ring gear. Depending on year and model vehicle, some starters you can replace just the starter drive otherwise you need to replace the whole starter. If you changed the starter look at the flywheel.
Sep 18, 2014 | Cars & Trucks
Starting
Return starter bc the starter solenoid is not engaging bendix, which engages the starter teeth into the flywheel..
May 17, 2013 | 2002 Pontiac Grand Am
Engine won't turnover
It sound like the starter solenoid that forces the starter gear onto the flywheel, you need to replace the solenoid unit.
Mar 30, 2013 | Rear Right Window Regulator & Motor for...
Starter spins but won't engage
The starter on your bike uses a solenoid that also manually engages the starter gear. Try lubricating the solenoid mechanism and verify that the mechanism does not bind or stick. Once you have the mechanism freed up, check the starter again. If it does not engage, replace the solenoid (or, while you're at it, just replace the entire starter assembly).
Jan 21, 2013 | 2003 Harley Davidson FLSTCI Heritage ...
Won't start.
There are a number of safety switches on mowers today for example one for the seat, pto (deck being engaged) There may also be a blown fuse as you said the hour meter is not working
Oct 23, 2012 | John Deere Garden
1982 Pontiac Firebird Trans Am, starter solenoid only engages sometimes (starter motor always spins), occasionally starter gets stuck ON, and sometimes no spark (fuel is fine but car won't start u
ANY FAULT CODES? HAVE YOU CHECKED THE STARTE DEPTH FOR PROPER CLEARANCE? HAVE YOU RITIATED THE FLYWHEEL TO LOOK FOR MISSING TEETH? I HAD AN 82 T/A AND THAT WAS WHAT CAUSED MY STARTER PROBLEMS. AS FAR AS NO SPARK DO YOU HAVE ANY FAULT CODES INTHE ELECTRONICS? TO TEST WITHOUT A SCNNER GO TO THIS LINK
Feb 11, 2012 | Cars & Trucks
Moto Guzzi breva 1100 won't start clicks at relay.
Take a look at the starter solenoid. There are two larger wires, on the back. One from the battery positive, (main hot wire), the other goes to the starter motor (If you jump these terminals the starter will spin but will not engage the flywheel). Look at the wires and nuts on the solenoid, especially the starter motor side make sure they are clean and tight, have not gotten hot and started rusting. Also check the voltage on the solenoid wire, (smallest) wire from the start button. In some cases there is a voltage loss on this wire. Next time it will not engage the starter right away, make a jump from the main power battery terminal on the starter to the solenoid wire. If it starts right up every time, you need to add and wire in another relay to carry the voltage to the solenoid from the start button, (a relay to work the solenoid, lol). If that test does not work or help.. Tap on the starter motor with a hammer. if it catches and turns the engine then, the motor brushes are worn and need to be replaced.
Sep 25, 2011 | 2005 Moto Guzzi Breva V 1100
Every so often when I try to start my 2005 F250 the starter will just spin. In every case so far when I try the second time, it will start ok.
If the starter is spinning without engaging the flywheel, chances are that the drive (called a bendix drive) is going bad. Part of that unit is a sprague or also known as an overrunning clutch. it's purpose is to permit the engine to spin faster than the starter when it fires up, otherwise the starter would explode due to the excessive rpm's. If the sprague is worn, or the gear slide is dirty or pitted, the gear end won't work properly. Since most times when that part goes bad, other parts of the starter are usually worn enough to warrant replacement, the best option is to replace the starter as a unit. (so in two weeks, you aren't taking it apart again to replace the brushes etc.)
Jul 18, 2011 | Ford F-250 Cars & Trucks
Riding mower won't start
Check the starter. Sound like the gear on the starter is stuck or broken off and not engaging flywheel.. Just your starter is spinning
Jun 16, 2009 | Mtd Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
