Question about Actiontec Computers & Internet
Actiontec GT724WG NAT from strict to open
SOMEONE PLEASE ******* TELL ME HOW TO GET MY NAT FROM STRICT TO OPEN ON MY XBOX!!!! TRIED EVERYTHING WITH THIS ******* PIECE OF **** GATEWAY AND NOTHING WORKS DMZ DOESNT WORK MY PORTS ARE ******* FORWARDED, UPNP IS ON AND I CANT FIND A SINGLE INSTANCE OF SOMEONE ELSE GETTING THIS WORKING WITH THIS DEVICE ****. IM GUNA ******* GO MENTAL. ******** MTS, AND ******** ACTIONTEC YOU ******* DOUBLE NAT PIECE OF GARBAGE.
    New Friend:
  • 24 Answers
Factory reset the router, 98% of time solves problem with Xbox, you shouldnt have to configure and thing after the factory reset, just reconnect via ethernet or wifi. you hold down the reset button on the back of the router for 12+ seconds while the router is turned on. wait 1-2 minutes for reboot
Posted on Aug 13, 2014
SOURCE: xbox live NAT
I have worked with tons of these netgears and I have learned that the netgear has a hard time with the port forwards. There is a couple things you could try to slove this
1. Upgrade the firmware. Netgear has upgrades on there site for every router and you should be able to up grade the firmware.
2. You must do a reserve ip address in the netgear. Setup the xbox to that ip address then do the port forwarding and it will work
3. You must have these ports forwared to that ip address
The following ports must be available for Xbox Live to operate correctly: • UDP 88 • UDP 3074 • TCP 3074
http://support.microsoft.com/kb/908874
As for the Dmz This is desgined to take you outside of the router firewall which Is ok if you want to setup. It did make a difference on mine
Posted on Oct 26, 2007
SOURCE: Can't connect to XBOX Live because of Strict Nat settings Netgear router WGR614
I tried to find this "Access Point Mode" on the WBR 1310 as suggested above and I couldn't. I spent hours on the phone with support from Xbox, D link, and my ISP Bell Sympatico's technical support trying to get my Strict NAT to Open. I finally got everything working and if you follow the instructions below in order, you will too. Here's what you should know if you have the D Link WBR 1310 and Bell Sympatico Internet.
1. Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your timezone. On step 3 this is important, select PPPOE setting. On the 4th step leave the Address Mode in Dynamic and enter the Username and password supplied to you by Sympatico.
Once you have configured your Router to work with the PPPOE settings that Bell uses (Most DSL providers use this setting) you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/Xbox_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mensioned on this page is for each port you forward under the box that says "IP Address" do not put the IP address of your computer. You put in the new IP address of the Xbox 360 which was one of the 5 that was generated on the previous link. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start, run, type in cmd then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Also after reading several forums you don't need to enable DMZ host and leave the UPnP enabled. By default they are set this way anyway. Hope that helps.
Posted on Jan 05, 2008
SOURCE: Strict NAT setting on XBOX 360
i have a Belkin N1 Wireless router and either have a moderate or strict NAT...the xbox chooses sometimes...but i am wondering if any one can suggest what to do
Posted on Mar 20, 2008
rahul26485
  • 611 Answers
SOURCE: My Xbox 360 Nat is Strict. with my Belkin
again give it then save it then reboot it the router then try it
Posted on Jul 29, 2009
govinda123
  • 2263 Answers
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Posted on Dec 10, 2009
I have a PK5000Z from Qwest, and an XBOX360, I had an issue previously with a PK5000 made by Actiontec, with NAT issues, set to moderate, it doesnt let me hear all players in a xbox live party chat, or in...
try turnig off all restrictions related. like , S.P.I. (statefull packet inspection) and try setting firewall setting for the address of the Xbox to "DMZ" . check setting of M.T.U. in router, adjust it to 1580
Good luck.
Sep 27, 2010 | Computers & Internet
Once i open my router how do i actually open the ports for xbox tcp80,udp88,exctra im using a action tec gt704wg wireless router
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Your manual above it also shows you how to open ports in there.
Also if you go to http://portforward.com/, they will show you how to do it too. Go to the link below.
http://www.portforward.com/networking/staticip-xbox360.htm
Actiontec Gateways and Routers are compatible with the Xbox. However, it may be necessary to forward the ports used by the Xbox, in the Actiontec Gateway or Router. Without Port Forwarding, the Xbox Connection Test may report a "NAT" rating of "STRICT" or "MODERATE", rather than "OPEN".
It is also explained below...
Aug 21, 2010 | Actiontec GT704WG Wireless Router...
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Ok my nat type is strict and i am trying to change to open
That will work.
Dec 09, 2009 | Actiontec Computers & Internet
Xbox 360.......strict NAT
I hope that this will be able to help you. It lists the necessary ports and the Microsoft knowledge base solution for this problem. If this is not a help please comment back and I will try my best to help again
Mar 25, 2009 | Belkin Computers & Internet
How do I turn NAT from strict to open on a 2.4GHz router
sir try to view your router using the web base configuration, locate the NAT configuration and enable DMZ function. it should open all ports with your xbox
Sep 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
Apr 20, 2008 | Belkin Wireless-N Wireless Router with...
How do i get NAT OPEN
To get the NAT open, you have to forward specific ports. If you are doing this for xbox live, then call microsoft and ask for an "agent." Tell them that when you test your xbox live connection, your NAT is strict or moderate. They will give you a specific port to open. With that information, You go to your router's setup, and look for port fange forwarding. Enter the information given and save it. For further assistance, call netgear's help line and they will help you.
Mar 31, 2008 | NetGear WGR614 Wireless Router
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
106 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
