Question about RCA L22HD31 22 in. LCD HDTV
When power on, lightturn green and then blue before shuting down
Picture starts out clear then slowly fades out to a totally blue screen. Audio stays fine.
your red and green guns inside are overheating and shuting off , investigate cause of overheat (coolant low or spilled out ?)
Mar 18, 2016 | Sony Televison & Video
Hi, I have a problem with my k52jc, at startup and lately even when shuting down, the graphics go crazy. The screen gets white, blue and green sometimes even b&w and it's like swirling colours and it...
I am guessing here. Is it Asus?
Try an external monitor to rule out the laptops screen. If the issue occurs on both screens, I think you have a GPU issue.
Dec 26, 2013 | Computers & Internet
Playstation keeps shuting off when I turn it on and it has red and yellow lights instead of blue and green
Yellow light of death (YLOD)
You have to take your console apart all the way down to the motherboard and flux and reflow the motherboard.
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
HELP!
i think the problem is of the power supply the board did not get enough power to stay on
Dec 21, 2009 | ASUS P7P55D PRO Motherboard
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
TV shuts down after a few seconds no picture comes on
I have LCD AKAI TV , It shuted down and no picture . Power never changes from red to green when I press remote control or standby button.
Oct 03, 2009 | Sanyo DP50747 50 in. Plasma TV
ECG Schiller AT1 shuting down in work
Most likely needs a new battery. Can be ordered from R&D batteries.
Apr 08, 2009 | Schiller Cardiovit At 1 Ecg Machine
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Does not turn on
when the green light flashes.. this mean the processor in the set is shuting the set down. for some saftey issue. it doesnt want to cause a fire or damage the set further. it can be one of many issues. techninicans have speacial equipment to read the set to determine the errors. this is pretty standard with this set
Dec 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L22HD31 22 in. LCD HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
