Question about Samsung ML 2010 Laser Printer
I have the replacement pickup roller large rubber band, but I do not know how to open the Samsung 2010 and slip the rubber band on the pickup mechanism. Advice?
  • Anonymous Mar 14, 2014
    pickup roller rubber replacement
    Champion:
  • 220 Answers
Two screws when you ope front door,at the back 4 screws.the front where screws are they are 2 lugs holding cover wedge out and pull cover off.
Posted on Jun 22, 2009
  • T2012 Aug 28, 2011
    This does not tell you how to take out the roller, it doesn't tell you that you need to take off the cover at the back either, so still no solution to my problem.
We have a Brothers Intellifax Machine, Model 2820, the problem is with the paper feed, the roller is not grabing the paper to feed it through the machine when we are receiving fax's. I would like to...
there are several fixes to this problem 1. replace pickup asembly 2. Clean the rubber pickup band are roller with a rubber cleaning compound (not alchohol0 alcohol dries out the rubber.
This is a common problem with printers and faxes, Paper has a tendency to leave a glass glaze on the pickup rollers therefore causing the paper to slip on the rollers are to be misfed thus causing a paper jam
Sep 23, 2011 | Brother Office Equipment & Supplies
Samsung ML 1430
http://degenportnoy.blogspot.com/2006/10/samsung-ml-1430-wont-feed-paper.html
Dec 10, 2007 | Samsung ML 1430 Laser Printer
I need to replace the rubber band in the roller.
see my post on jan 2013 on the ml2010 paper feed problem.
Aug 30, 2011 | Samsung ML 2010 Laser Printer
The paper keeps jamming but i cannot see any paper anywhere in the printer.
Sounds like a pickup roller is slipping....I recommend a product called Rubber Rejuvenator which you can buy at Staples or Office Depo....It comes in a spray can and you spray it on the rubber rollers and it softens the rubber allowing it to grip the paper. Its completely designed to clean these rollers and its what the pro's use! Hope this helps.
Oct 21, 2010 | Samsung CLP 300 Laser Printer
Pickup roller fails to load paper sometimes from the paper tray.
I have a Samsung ML1610 mono laser printer which I fixed this on, but lots of Samsung printers have the same issue and fix. The pickup roller shrinks so that it doesn't feed the paper consistently. This gets worse over time. And replacements, from suppliers advertising on eBay, come as two parts. There is a fat "rubber band" which is stretched over a removable u-shaped plastic core, and there is a video on YouTube showing how to replace these parts (see below). You can buy either just the rubber band or the plastic core as well. But my tip is that, if you remove the rubber band and plastic core, you can turn the old rubber band inside out (if it is not yet cracked) and the edges of the old band now stick out and make it work reliably again for a limited time while your replacement part order arrives. I am leaving my old one to see how long this fix lasts: it has lasted about a week so far with smooth printing. And if this fix fails, it might indicate that this is not the correct fix for your printer. This video shows a fix; a small screwdriver or a bent piece of metal (and strong fingers) is all you need to do the repair.
Feb 15, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Rubber band slipping to edge of the silver spoke
Hi thanks so much - the vacuum is an upright morphy richards model number 73360.
We kept re-alligning the band into the middle and rolling the brush round several times with our hands to make sure it wouldn't spin off. The roller that the band fits on is very wide so you just put the band in what you think looks like the middle.
It was unbelievably sensitive and had to have it "exactly perfect" to the millimetre otherwise the band would just continue to slip off. It appears to be working for now so lets see how long it lasts before the smell of burning again! Many thanks for advice.
Aug 15, 2009 | Vacuums
Pickup Roller wear
I have had the same paper jam nightmare as many CLP-300 users and just as I was on the verge of throwing it away I appear to have solved the problem. The paper tray has adjustable plastic guides on either side. I loosened them slightly to allow an spare eighth of an inch each side and I've had no problems since. I can't believe the problem that plagued me for months was so easy to fix.
Feb 01, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP300 cannot get the rubber pick up roller back in
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Aug 16, 2008 | Samsung CLP 300 Laser Printer
Help
The only way to do this is with 2 small flat bladed screw drivers when u push them at the same time into the edge where the clips are one either side of the roller the whole roller will come off. If you can see opposite the clips there is a sort of hinge section this hinges down and the whole roller and rubber comes free. I just turned the rubber inside out and refitted it no more paper feed errors. It is a little tricky to reach and you definitely need the screw drivers to slip in the edge as pushing on the little lever to release it wont slip it past the notch that holds it in place. Good luck.
Aug 14, 2008 | Samsung CLP 300 Laser Printer
Samsung ML-2010 won't feed paper
This is a step-by-step process for replacing the tire (roller). Thanks to dizzyzuma for helping me get the right part and get the procedure down.
1: You will need to manually shut off the printer in the middle of printing in order to release the tabs. Put in a few sheets of junk paper and print a few blank documents. You want to shut off the printer using the switch in the back when the roller is approximately in this position:
2: Hold the down the two side tabs that are locking the tire into place and press down on the tire with your finger. It should pop off relatively easily.
3: Turn the printer back on. The tire will rotate around to its starting position, but it will now be unlocked. Turn the printer back off.
4: Rotate the tire towards you and unhook the two bottom hinges. It should come off without much force.
5: Replace the old tire with the new tire.
6: Re-insert the tire onto one of the bottom hinges and rotate it around so that both of the bottom hinges (tabs) are in.
7: While holding the back of the metal bar with your fingers for leverage, press firmly with your thumb to snap the tire back into place.
8: Turn back on the print. You’re good to go.
Mar 15, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
678 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
