Question about Wowwee Roborover
Roborover blinks green - Wowwee Roborover
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Roborover
check for weak batterys and replace them in the roborover then try agine then check batterys in remote if still having problems see wowwee .co
Feb 08, 2013 | Wowwee Robotics Roborover Talking Rc Robot...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
My O2 Atom on normal mode binks in blue colour and there is a missed call or sms blinks in orange (or red). from yesterday it blinks in green on normal mode. Can you please tell me why? Anything wrong?
The notification lights indicate:
Blinking Blue - Bluetooth On
Blinking Yellow - WiFi On
Blinking Green - GSM (Phone) On
Blinking Red - Unread message
Continuous Red - Charging
Blinking green when your GSM (phone) is on is the expected behavior.
May 02, 2011 | O2 Xda Atom Smartphone
Wowwee roborover just says thanks alot on power up, remote don't do nothing, new batteries in both.
I just bought one off an online auction site and have the same problem I got a refund on it but it would be nice if I could get it to work properly
Sep 24, 2010 | Wowwee Robotics Roborover Talking Rc Robot...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light blinks
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
Sep 21, 2007 | Kenwood Radio TK2200 TK3200 Compatible...
Wowwee Roborover Logo
32 people viewed this question
Top Wowwee Toys Experts
Michael Vincent Cruz
Shekar Avadhani
Tom Chichester
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
