Question about Kocaso M1066 Android 4.1 Dual Cameras 8GB 10.1 Tablet PC Allwinner A20 Dual-Core 1GB DDR3 RAM Microphone Built-in Google Drive
Only one USB port
Can i put a 1 into 2 hub on it and plug my mouse and my keyboard into it and have it not mess anything up and work.
  • Kocaso Master
  • 3,320 Answers
Yes
Posted on Apr 13, 2014
Testimonial: "Thanks mike m"
Is there a separate keyboard that works with the original 7 inch rca voyager tablet? does the voyager have bluetooth already in it to work with those keyboards or not?
Blue tooth keyboards come with a dongle that operates them. If you have an unused USB port just connect a keyboard that has a USB plug on the end of it's cord.
Oct 24, 2016 | Tablets & eReaders
Is there a mouse that works with the kindle fire 5th generation? Bluetooth maybe?
Jodi, Yes, you can pair it with Bluetooth mouse and possibly through mini port. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Connect to Bluetooth
Kindle Fire Wireless mouse and keyboard on ICS
Using Qwerty Keyboard Mice and other USB device on Amazon Fire 2015 via...
Can you connect both bluetooth mouse and keyboard to Kindle HD Fire 6
May 03, 2016 | Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Is there such a thing as a mouse for tablets?
hi I have used a tomtop mouse on a nexus 7 it works ok all u need is the female to mini usb plug available from dick smith ...
Jun 30, 2015 | Visual Land Connect 9" Android Tablet...
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
How to use keyboard and charge device simultaneously
Plug in a small two port usb hub then you should be able to connect power and keyboard at the same time.
Nov 02, 2013 | ZEEPAD Tablets & eReaders
I have the leather case with the keyboard but cannot attach to the android table that was sent
well thats strange,, the tablet has 1 USB 2.0 port and the keyboard connects to that port as its standard.. Its a standard port so all usb 2.0 connects for it is standard.
http://www.amazon.com/Coby-MID7015-Android-Internet-Touchscreen/dp/B0047Q9GT4#productDetails
and
http://www.amazon.com/Tablet-Stand-USB-Keyboard-Carrying/dp/B004OB0EBQ/ref=pd_bxgy_pc_img_y
is what u have right ??? try turning the connector around.. It should fit.
Dec 30, 2012 | Tablets & eReaders
Kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Jan 01, 2011 | Amazon Kindle 3G
Key board and mouse is locked
Try plugging an external keyboard and/or mouse.
See if that works.
Oct 25, 2007 | Compaq D70045-236 Tablet PC
Kocaso M1066 Android 4.1 Dual Cameras 8GB 10.1 Tablet PC Allwinner A20 Dual-Core 1GB DDR3 RAM Microphone Built-in Google Drive Logo
88 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
