Question about Kenwood With difficulty CD / USB deck U535
U535 Always at the Protection Mode
My U535 stereo not functioning every time i open it.,its blinking with the word "PROTECTION".What should i do?
5 Suggested Answers
imseth85
  • 30 Answers
SOURCE: Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Posted on Mar 31, 2008
  • 182 Answers
SOURCE: how do i get my kenwood kac-8402 out of protection
first thing first open it up ull need to check ur heat sinks and capacitorsand see if any of them are blownd if there are blowend replace the bownd once. and try it
Posted on Jul 08, 2009
SOURCE: my amp just shut off and wont come back on I think
where can you get this fixed?
Posted on Mar 12, 2010
  • 5 Answers
SOURCE: stuck in protection mode tried
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Posted on Feb 09, 2011
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Receiver standby sound
If the receiver goes into protect mode with no speakers connected, you will have to troubleshoot the receiver itself to find and correct the problem.
Mar 07, 2014 | Onkyo Audio Players & Recorders
Kdl60ex701 blinks 7 times
It's going into protection mode
Open it up and check capacitors, power supply ect
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Jan 17, 2014 | Televison & Video
My sony bravia kdl-32s3000 keeps turning off and the standby light is flashing 5 times
Just a copy from Sony:
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board. First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
Oct 24, 2012 | Sony KDL-32S3000 32 in. LCD Television
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
Protection mode
you have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Mar 31, 2008 | Onkyo TX-SR502 Receiver
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Kenwood With difficulty CD / USB deck U535 Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
