Question about Sharp Microwave Ovens
Sharp r350l I have a R350 l.When i switched it on to heat some food it ran for about 10 secs then a loud bang.Every thing still works,the rotating table,digital screen,cooling fan.It will not heat anything now.Your help would be appreiciated.thank you.
    Scholar:
  • 126 Answers
Sounds like an electrolytic blew, but it could be any nuber i=of things. Usually when one element fails, others are damaged and are failing as well, such as the magnetron.
If it is an inexpensive table-top microwave, it would be less expensive to replace it with a new one.
Posted on Apr 14, 2014
catriver
  • 878 Answers
SOURCE: My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Waleed, Since the microwave is going through all its motions we can feel safe that the oven and magnetron thermostats are ok. If they were bad you would not have a display. Just inside the control panel to the left, you have 3 switches which the door activates. A primary (top switch) a secondary (bottom switch) and a monitor switch (middle). If the primary or secondary switch is not closing when the door is shut, you high voltage side will not activate, therefore no heat. If the monitor switch failed or found either the primary or secondary switch closed with the door open, it would blow the main fuse and the oven would be dead. Therefore Im leaning on either the primary or secondary switch not operating correctly. When checking these switches, unplug and discharge the capacitor. This is high voltage. Good luck
Posted on Jun 17, 2006
SOURCE: Microwave makes a loud noise while using.
After you turn it on, it's a loud noise like it's coming from the fan, but other then that it works wonderfully.
Posted on Oct 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Error code ee1 on sharp r-22at
EE1 on a Sharp commercial microwave is magnetron 1-related failure.
It may be a bad connection or relay on the control board, a bad magnetron, a bad high voltage diode, etc. - anything in the high voltage circuit for the #1 magnetron.
We have the service / repair manual for a similar model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips, but do not rely on the part numbers shown in that manual.
You can find part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
Most computers will open the manual automatically, but you may need the free Adobe Reader
Posted on Jun 08, 2009
SOURCE: sharp carousel II microwave/convection oven
Hello, I just purchased a Sharp Carousell II convection microwave oven, also built in 1990, serial number 212806. I think the model number is R18244, but part of it is worn off. Can anyone tell me how to get a manual for it? I have never cooked with a convection oven before.
Thanks
Posted on Nov 14, 2009
How to fix loud hum and no heating in Sharp model R-308KW?
There could be a variety of reasons why this happens, but the likeliest
reason is the secondary interlock or monitor switch is broken. These are micro switches that tell the microwave that the door is closed. If this switch is broken, then the microwave thinks the door is still open and the carousel table won't turn, and the oven will not heat up.
I replaced an interlock switch last Saturday. The switch was $7.00 and took me an hour.
Ask your local repair person to test the interlock and monitor switches first, then go from there.
Good luck,
Hank
Jul 09, 2014 | Sharp R-308KK / R-308KW 1100 Watts...
I have a sharp R 350 l. when i switched it on to heat some food it ran for about 10 secs then a loud bang.All functions work except that it wont heat anything.
Sounds like an electrolytic blew, but it could be any number of things. (Failure of one element could cause the failure of others, such as the magnetron, as well.) You could have it looked at, but if it's an inexpensive table-top microwave, it's less expensive to just go buy another.
Apr 13, 2014 | Sharp Microwave Ovens
My micro wave stop heating food, every thing dislay work fine. when start it make loud sound. Sharp carousel II, model = R-3A54, Manufacture jan,1993
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | Maytag MMC5000 Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Cooking
I would say the high voltage diode blew.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
If it's not the high voltage diode, reply back for further help.
Oct 24, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
