Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
32"VIORE 32NAFC-UTA LCDTV... Powers on shows video for a few seconds, screen turns black. Tried several times same results. The power led stays blue till I power off, the turns red..
  • cfsor Jun 18, 2009
    Is there a service manual available! , is so let me know where to purchase it...
    THX, Bob
The manual can be found here (may take a while to download and is free - their site is a bit slow).
You can also contact Viore here for further support.
Best regards.
Posted on Jun 18, 2009
    Brigadier General:
  • 3,917 Answers
It's the power supply to the LCD panel. If it is under warranty send it to get fixed. If not throw it away, not worth the expense. Not seeing any fried components means nothing as it could be a 1 ohm resistor that acts as a fuse and it would not appear fried. You have to measure the voltages and to do that you have to know what they should be and at where on the board, which is beyond the scope of most people. If, you happen to be one of those people you will find getting any parts that are not standard fuses or resistors or capacitors extremely difficult, if not impossible.
Thanks for contacting Fixya
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
VIORE 32"LCD lc32vh70 Has sound but the screen turned in black
Does it turn black after about 10-15 seconds? My 40" Viore had the same problem. After trial and error, I finally fixed the problem. There is a motherboard with a cable wire coming from one end to another motherboard. 3 wires. If you remove this wire and kind of jiggle it it in, barely touching the contact points, you will see the image stay on longer than 15 seconds. You have to cut one of the wires on the board with all the inputs, VGA, HDMI, power cord, etc. I have taken pics but have not taken them out of the camera yet. If interested, post back here and I'll (hopefully) get them out. But a word of caution: my 40" inch TV motherboard may be different than your 32" inch.
Feb 08, 2014 | Televison & Video
Kv-32fd1e vertical scan instability
Post this query in a forum dealing with televisions, please - this one is for camcorders and allied equipment.
Jun 27, 2017 | Panasonic Video Cameras
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I TURN MY TV ON IN A FEW SECONDS GOES BLACK .BUT THE GREEN LIGHTS STAYS ON
The internal power supply is failing. The green light merely indicates that house power is getting to your TV
Aug 08, 2013 | Viore 32" LED LCD HDTV
My 19v712m manga box tv goes black
The steady blue LED merely indicates that power is getting to your TV. The internal power supply may have failed
May 15, 2013 | Televison & Video
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
-Orange light on Power-up button stays lit. -No Video, just black screen. using AGP Video card TNT 32mb / Model CT5823 I've replaced the battery, double checked the cables, Power supply is good. Gatew
This is typical of a failed power supply. Look on the back of the power supply, there may be a red switch for input voltage. Unplug the power cord, flip that switch a few times and then plug the cable in and try again. If nothing changes, see if there's a small black button on the back of the power supply. If there is, unplug the power cable and press the button and hold it for 10-15 seconds. If an LED flashes or turns on, then plug the cable back in and try again. If this all fails, replace the power supply.
May 17, 2009 | Gateway Computers & Internet
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
132 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
