Question about Jandy AQUALINK RS TELELINK KIT
I have an Aqualink RS4. I want to delete the 3 programs scheduled under filter pump. How do I do that?  Thanks
  • 15 Answers
The best thing to do is to clear the system memory. Aqualink can have a problem with "ghosting" Things just go on by themself when not programed to. A bad spa side remote can do that to but that is another problem.
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till diplay says " clear memory "
Push star or enter
Push star or enter again to comfrim.
You will get a message "earsing memeory"
Now you can reprogram system
If you want differant run times like a summer and winter timing you can do that with the program groups
Hope this helped
Keith
Posted on Jun 23, 2009
How can I disable the pump clock on the intelliflo variable speed pump
check you tube for programming you have to put it into the controller mode or it will override it
Aug 11, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Aqualinks rs4
Go to menu , program the pick pool and input your desired schedule.
Make sure the day and time is set correctly!
Jul 21, 2014 | Jandy Aqualink Rs4 One Touch Control...
How do I cancel filter programs
go to system setup go to program if there is a program it will let you edit or delete
Apr 02, 2014 | Jandy Aqualink Rs4 One Touch Control...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink RS4 Filter pump relay switch location
relay behind lower panel above breakers with red and black wires to it
Apr 13, 2011 | Water Pik Aqualink Rs4 Package - Pool and...
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
Program Group A is selected and the filter pump is programmed to start at 12 noon but does not turn on. If I start it manually, it runs fine and will turn off at the proper time. What could it be? ...
Check to see if your nine volt battery is good. The aqualink will hold it's programs but lose time and date. At that point it goes back to factory set. You have to have a fresh battery to avoid this.
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy AQUALINK RS TELELINK KIT  Logo
1,814 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
