Question about Bissell 9400-3 ProHeat 2X Select Pet Upright Deep Cleaner
The smartmixer switch want work on my bissell proheat pet
  • 3 Answers
SOURCE: Bissell 1699-1 reassmble
I FIGURED IT OUT!!!!YAY.
the piston comes out easily with a pair of plyers.hold the cover on your lap upside down, smart mix knob closest to you,there is a slot for the piston to fit in to, turn the knob slightly (about 1/2") you will see that you can lift the knob slightly out of the way then you can slide the piston into place. leave the knob at that position to hold the piston and slowly put the cover back in place. if the piston goes in,just before you put the cover all the way down turn the knob back to water only.if everything is in place, PUT THE SCREWS IN!!!! hope this helps.
Posted on Jul 31, 2008
  • 29 Answers
SOURCE: Bissell Proheat 2x Not Putting
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My Bissell model is different than yours, but many are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
ffuutr
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I think my bissell proheat 2x is plugged up with pet hair.
heatman101
rrtjgh
Bissell proheat pet expelling too much water
Hi Jessica. If you're experiencing continuous spray, you may want to have one of our Authorized Service Centers inspect your machine.
Here's a link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Sep 21, 2013 | Bissell 9200P Deep Cleaner, ProHeat 2X Pet
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Doesn't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
If your belt is worn out or broken, here's a direct link to that belt on our website:
Bissell Pro-Heat, Pro-Heat 2 6960W Replacement Pump & Brush Belts
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Won't Spray
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissel proheat is not releasing the soap when the trigger is pulled
Try these suggestions to get your machine working properly:
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Aug 13, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can not get the Smartmix rotary switch to line up
heatman101
fsd5
May 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My brand new bissel little green proheat pet series is spraying solution however it's not hot when it comes out. I put hot water in the tank & turned the heater on. Isn't this the whole point?
Have you checked the user manual? Can be found at http://www.bissell.com/searchresults.aspx?searchtext=little green&mode=userguides
If there is no element then the water will cool down naturally.
May 21, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
heatman101
rrtjgh
Sep 05, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 7920 Carpet Cleaner
I managed to sort this. The small plunger valve sits in a little square crevice next to the smartmix dial - it does NOT sit in the middle as it first seems. You then have to get the lip of the smartmix dial to sit in the cut out on the side of the plunge valve so that it moves up and down when the switch is turned.
It take patience, but it is possible - no need to use any force.
Dec 18, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9400-3 ProHeat 2X Select Pet Upright Deep Cleaner Logo
13 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
