Question about Apex Digital AT2014DV 20 in. TV/DVD Combo
Remote won't work on my lg bpm33 - Apex Digital AT2014DV 20 in. TV/DVD Combo
My Blu-Ray player will not play Netflix anymore. Model #BPM33 It's not a Netflix problem. I got a message stating I need more storage space and I don't know how to do that.
Look in setting and look for format they have built in hard drive. Some you have to delete some streamed movies that install automatically.
Jun 11, 2016 | LG Recertified - Streaming Bray Disc...
Looking for lg blu-ray disc player manual for bpm33
This seems to be the manual: http://www.lg.com/us/support-product/lg-BP300#
Apr 10, 2013 | Televison & Video
My lg remote won't work
The remote itself can be tested by almost any TV shop to see if working or not---pointed at a tester and any or all buttons pushed to see if remote is working or not.
Many digital cameras will in a very dark room react in same way with a faint flash on the camera display when buttons are pressed.
If remote tests good the set does have a remote receiver built into the front of it, that would be suspect if the remote checks good.
Oct 15, 2012 | LG Mkj40653801 Factory Original Remote...
Tv will not work with remote remote works
Sometimes this happens, check the back of the tv of the for the light bulb sometimes it may go out and the tv won't work you may have to unscrew it your self though or get some help goodluck!
Sep 20, 2012 | LG 26LG30 - 26" Class / 720p / 60Hz / LCD...
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
I am trying to add my lg tv device to my Panasonic DVD player remote, but I can not find the code for the lg tv. The model of the tv is 32LC2D.
Hello...Here are some remote codes to try...0004, 0005, 0050, 0009, 0227, 0338, 0012, 0057, 0080, 0156...Hopefully..you won't have to go thru them all before you find one that works....I hope that this was helpful....PEACE...
Jan 25, 2012 | LG Televison & Video
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
TV remote won't work. Batteries are OK. LG remote not programmed to change channels
Is it the original remote of the TV? or an "all in one" type???, if it's the original remote you don't need programming, if the batteries are fresh and correctly installed, than check the InfraRed output with the help of a camera... The human eye cannot see IfraRed but cameras do... so point the remote to anny camera (with video capabilities) and press the buttons on the remote, if you see the IR Lights flashing through the camera, than the remote is working, if not than the remote is dead, check for cold joint solders inside or buy an all in one remote...
Aug 09, 2011 | LG 42LC2D 42 in. LCD HDTV
Unlock the region code
1. Open DVD tray
2. Press the '0' key on the remote three times, waiting about one second
between key presses. The 'Region Test' screen will appear on the TV. If you don't
get this screen, then power off/power on again and start over.
3. If the Region Test screen appears, enter '0' for all-regions.
4. Press pause to save and exit.
May 18, 2008 | Televison & Video
Apex Digital AT2014DV 20 in. TV/DVD Combo Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
