Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
