Question about Compaq PS/2 3 Button Optical Mouse 51876724331
Drivers compaq ps2 mouse 5188-2465 - Compaq PS/2 3 Button Optical Mouse 51876724331
Cannot detect my usb mouse in Windows XP
Did you UN-installed the USB mouse driver in the device manager?
If not to this.
Are you using a USB mouse ?
If yes :) update the driver using the device manager
If no now using PS2 :) update driver using device manager, and select the ps2 mouse driver.
Feb 15, 2012 | Dell Dimension 3000 PC Desktop
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
Nov 24, 2011 | SuperMicro Computers & Internet
Won't move anywhere on the screenhow do we know if we need to replace the mouse
Is it a wireless mouse? If so you may need to replace the batteries and re-sync it with the receiver unit. If it is a chorded USB mouse you may want to try a dif. usb port and see if that works. If it is a PS2 mouse you may need to replace it.
Usb - Flat square shape
PS2 - Small round shape.
Jun 19, 2010 | Compaq PS/2 3 Button Optical Mouse...
I have a new Dell computer, which has no PS2 port.
No, unfortunatly there is none unless you specificaly ask Dell for a usb driver.
It's a common myth that users think USB has built in drivers in it's hardware. The only resolution to this issue is to ask the manufacturer for a new driver for this specific item to run under usb.
Mar 05, 2010 | Fellowes Touchpad STD PC (platinum)...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
Right button wont work
Have you tried using another "external" USB or PS2 mouse on this laptop? Also if you haven't already, you should try to find the latest drivers for this particular model and re-install them. You might be able to find the drivers here --> http://www.compaq.com/cpq-country/cpq_support.html. Just put in your laptop's model number and choose "Software & Driver Downloads" from the list. Hope that this helps.
Serge C.
Apr 02, 2009 | Compaq Computers & Internet
Ps 2 mouse no driver install
Windows has inbuilt driver for all the mouse. YOu dont need to install the driver separately for your PS2 or USB mouse.
The reason why yours is not moving can be
1) Mouse cap/IC gone bad & needed to be changed a new mouse
2) OS faulty (very rare 1 out of 100)
Jan 21, 2009 | Computers & Internet
Mouse trouble
start (button) select control panel / system / hardware / device manager / mice & pointing device / double click, select wheel mouse (or whatever mouse you have) right mouse click, properties, select use this device (enable) - But I'm surprised you are having trouble with it.. Have you changed anything recently? Have you always used a ps2 mouse? Try connecting the mouse & re-booting the pc.. Also make sure it's plugged into the correct port, not the ps2 keyboard port.. Especially checkif you are using a usb keyboard.. Rgds
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Reloading XP on dc 5100 hp compaq
Mice don't normally need a driver unless you wish to assign special buttons and clicks, assuming your mouse is a PS2 connection, try a USB one instead, that should work.
Nov 30, 2006 | HP Compaq dc5100 Small Form Factor PC...
Compaq PS/2 3 Button Optical Mouse 51876724331 Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
