Question about Duraflame Electric Fireplace Stove DFS-750
NO FLAME HEATS BUT NO FLAME
  • 62 Answers
There are little light bulbs (like large Christmas lights) that have probably burned out.
remember to replace with only the same wattage and type.
Posted on Apr 01, 2015
Heater ignites when holding knob in as soon as you let go flame goes out so basicly it wont stay lit
safety interlock is not being disabled. Older types have a mercury filled bulb flame sensor, newer types have a thermocouple or millivolt sensor. Diagnose and repair the safety shutoff interlock, when the flame heats up the sensor the gas valve should keep the flame lit on its own.
Feb 23, 2015 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Trying to light a new gas dryer. was unaware it was gas lol
Gas appliances normally require a pilot flame. This flame heats a thermocouple which operates the main gas valve when you want heat. The pilot flame may be out. Gas valves have a start-up process which normally requires you to press and hold the pilot flame button for up to 30 seconds (until the thermocouple heats up).
Your appliance will have been delivered with a user's guide in which you will find the pilot lighting procedure...OR...there may be a guide adjacent to the gas valve.
Apr 12, 2013 | Dryers
G4-7 atwood water heater lights great, heats water but when it cycles the pilot goes out no hot water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
May 10, 2010 | RTO Atwood Water Heater - 6 Gal LP
My propane fireplace pilot light wont stay lighted help
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Mar 17, 2010 | Desa International CCL3018N 18KBTU VNTFRE...
Ge gas dryer heats up at first but thats it
You need to change out the coil kit.
Mar 13, 2010 | GE Dryers
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Pilot adjustment on Williams wall heater
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Dec 02, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Duraflame Electric Fireplace Stove DFS-750 Logo
229 people viewed this question
Top Duraflame Home Experts
Donni Steen
Tom Chichester
Are you a Duraflame Home Expert? Answer questions, earn points and help others
