Toshiba 6550 copier starts but then says close right front cover, the cover is closed, i have unplugged and plugged back in, cannot get it to work
  • 92 Answers
Look for the hole that lines up with the actuator that tells the machine the door is closed usually a mettle flat long part sticking out the inside of the door stick something in the hole it lines up with and see if the switch is being pushed into the on position if you can do it by hand then its a matter of repositioning that switch by reforming the switch actuator wont be easy you have to take off the cover to expose the switches
Posted on Jun 26, 2009
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
Close side cover means in toshiba estudio182
You see front cover switch if front cover knob not touch then this messege appear OR check power card & front cover connection
Jan 04, 2014 | Toshiba e-Studio 232 Black and White...
Close side cover error tray
Nov 06, 2013 | Toshiba e-Studio 350 Copier
Make sure the front cover is closed firmly, triggered the front switch, u can see clearly by removing the paper exit tray.
It might be front cover switch problem also.
Sep 27, 2013 | Toshiba e-Studio 350 Copier
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
Sytem error e000
Solution: Reset the unit-ICMF 5500/5700
Reset the unit
  1. Open the front cover.
  2. Close the front cover.
  3. Unplug unit for 3-5 minutes, then plug the unit back in.
Dec 30, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Close front cover
Unlikely the power supply. Sadly I can't think what causes that. I havent workrd on Toshiba for a couple of years now, but there is something else that causes that. Totally unrelated to the power supply or the switch. Have them call Toshiba support .
I am sorry I can't off hand remember the problem. But it is unlikely the power supply.
Jul 23, 2010 | Toshiba E-STUDIO 850 Copier
Close front cover
THERE IS A PROBLEM WITH ONE OF THE COVER SWITCHES. EVERY COVER HAS A SWITCH, ONE OF THEM MAYBE STUCK, BROKEN, OR MISSING. GOOD LUCK.
Jan 12, 2009 | Toshiba COPIERS E-STUDIO 520 Copier
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
136 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
