Question about Kenmore Washing Machines
FOOT SWITCH DOES NOT WORK ON VACUUM CLEANER MODEL 116.59229210 ON OFF BUTTON OPERATED BY FOOT
CAN NOT REMOVE COVER TO LOOK AT SWITCH
reddevil6
  • 1673 Answers
SOURCE: remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Posted on Jan 05, 2008
  • 14 Answers
SOURCE: Replace on/off power switch for BUC11700UC vacuum cleaner
Bryanv
Thank you for and excellent solution. I have several suggestions:
1) After removing the 11 screws as directed, I was unable to remove the handle. However, I was able to sneak in and remove the one screw that holds the top front thingy. I should warn you that it is easy to break the tab at the switch end of the front thingy. It was zip wired to the handle. (How do I know, I'll let you guess:-)
2) I would recommend re-soldering the wires to the new switch. They are already tinned and take up much less room than push on connectors.
3) Finally, be sure to use insulating shrink tubing. Put it on before soldering. Duh!
Posted on Apr 11, 2009
b0sslady2001
  • 357 Answers
SOURCE: The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Posted on Aug 07, 2009
  • 430 Answers
SOURCE: How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Posted on Sep 17, 2009
SOURCE: I need to remove the
Remove the on/off button & the cord retract button. There are a futher 4 screws keeping the whole thing together.
Posted on Jul 10, 2011
Vacuum power was intermittent and now stopped working. Could be switch or rewindable internal power cord connection?
What vacuum are you talking about? model? make? was there any smell associated with the item stopping working? did you smell burning?
May 02, 2016 | Vacuums
Foot power switch is not staying on. Is there a way to take cover off power switch foot plate?
It may be a bad switch. You didn't state which vacuum you have but many have a plastic pedal that snaps into a couple slots. It's usually possible to pry it out to remove the cover.
Apr 30, 2016 | Vacuums
Model VC248. How do I remove cover to replace power switch?
[PDF]User Manual
www.cirrusvacuum.com/.../CR69A,79,99%20UPRIGHT%20MANUAL....
any openings or moving parts of the vacuum cleaner. I ... Cover 0 o l L I Hose cuff. Furniture lljm- 5 j. Guard _ u _"°-*_-'e"'"__ .' . ..... Cirrus wilt, at its option, repair or replace a defective vacuum or vacuum cleaner part that is covered by this ...
Sep 19, 2015 | Cirrus Vacuums
I have a Electrolux canister model L-E (circa 1986). Won't turn on. I think the foot switch is broken inside. Was working fine - turned it off then would not turn on BUT foot switch sounded different,...
I have one of these LE models also. Yes, the on/off button is broken. I have had to replace it twice on mine. My local vacuum repair shop suggested NOT to use your foot to operate this switch, but just press it on or off with your fingers. That will help to keep it from breaking.
Jan 10, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking apart?
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
Jan 25, 2009 | Kenmore 22812 Bagged Canister Vacuum
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Apr 13, 2008 | Kirby Heritage II Vacuum
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
