Question about Briggs & Stratton Garden
Briggs & stratton ohv engine sometimes smokes profusely.
Has episodes of smoking profusely when engine is under load or not level
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Maybe oil level to high
Posted on Jul 14, 2014
5 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: Briggs & Stratton twin with overhead valve engine.
Hi, check the engine oil level. It will be most likely over full as it has become contaminated with fuel, if so you will be able to smell fuel on the dipstick. If thus is the
Posted on May 05, 2011
  • 6468 Answers
SOURCE: Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
Posted on May 10, 2012
  • 6468 Answers
SOURCE: Engine smokes on Ariens Zoom 1634 34 inch Zero Turn Riding Lawn mover with Briggs & Stratton engine
check to see if the oil smells like gas the needle valves go bad in the carb and overflows into the crank case also head gaskets go bad and **** oil in from the crank case
  • 13 Answers
SOURCE: Briggs & Stratton R mower engine started smoking now won't start
magnito problem sound like
Posted on Jun 27, 2012
Briggsload Stratton 14.5 HP single cylinder OHV gasoline engine has episodes of severe smoking when
When what if you are saying when starting..after sitting..the oil from your overhead valves are seeping into the heads through open valves..when not running..most likely bad valve stem seals...
Apr 12, 2014 | Briggs & Stratton Garden
LAWN MOWER HARD STARTING WHITE SMOKE
White smoke would indicate a fuel problem. The engine is flooding.
There are a lot of possibilities but the first area I would check is the carburetor float level and inlet needle.
Dec 24, 2012 | Briggs & Stratton 190cc 875 Series OHV...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
May 05, 2011 | Garden
I have an old 3.5 hp Briggs and stratton on a masport lawn mower, it has started blowing smoke when it is unning, could someone give me a clue as to whether this is likely to be rings, vaulves, etc, or is...
Start by checking the oil level. It should not be overfull. If it is it will smoke, and it will soak your air filter , then foul your plug.
Check this first.
Let me know,Matt
Dec 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
146 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
