Question about Sewing Machines
Feed dogs are too low on Kenmore 158 12472 sewing machine - how can I raise them?
I have never had a problem with this machine - bought it new in 1981 - used it at Christmas 2013 and no problem - took it out to make twin quilts for twin granddaughters and feed dogs aren't feeding the fabric. I can't figure out how to raise them and can't find my old manual. I can see how they raise and lower but wonder if there is an adjustment that I can make to raise them up.
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
SOURCE: Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • 323 Answers
SOURCE: My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
Feed dogs up?
If the feed dog lever does not raise the feed dogs, then they are probably stuck. Probably needs lubrication. Since the make/model was not specified, would recommend taking it for service.
May 11, 2016 | Sewing Machines
Kenmore sewing machine 158-17182..sold by sears.. it was bought in 80s..I need to raise the feed dog..the fabric won't feed. .
I believe the solution would be to adjust the foot down till you achieve your fabric feed. GOOD LUCK FRIEND.
Sep 23, 2014 | Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Nov 24, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Machine quilting
To stipple ,remove the ankle and foot, lower the feed dogs and, most importantly, lower the presser foot lever.
You can also buy a LOW SHANK darning foot which will help prevent skipped stitches. It must be screwed onto the machine instead of snapping on.
sewman7
Oct 29, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sep 15, 2008 | Sewing Machines
Kenmore 19153
Sounds like you need a new needle and the upper tension tightened. Try putting machine oil on the feed dogs and working it up and down until it is free again. You can take off the lower plate and clean any lint that may have collected underneath. Then make sure the thread is coming out of the bobbin correctly before it is inserted in the machine.
Zelma
Jan 18, 2008 | Kenmore 19233 Computerized Sewing Machine
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
