Question about Bosch Evolution 700 Series HGS7282UC 30" Freestanding Gas Range with 5.1 Cu. Ft. Capacity, Genuine
Bosch one burner doesn't spark
Wrong burner sparks when knob turned on
3 Suggested Answers
comax
  • 154 Answers
SOURCE: bosch table saw model 4000. Brushes where sparking alot .
It sounds like the armature is gone, if you are lucky the field coil is ok. Pull the back of the motor off and have a look at the armature where the brushes run if it looks burned or really rough the armature is gone and must be repalced.
Posted on Jan 11, 2010
heatman101
  • 43501 Answers
SOURCE: My bosch gas top spark lighter doesn't work on any
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Contiually sparking on all burners
Ignitor trigger button/knob pushdown may be jammed, remove power and remove the knobs, spray with a small amount of WD-40 or penetrating lubricant, try to actuate the trigger by pressing it down and releasing, replace knobs if you need to, apply power and see if your issue is solved, if this doesn't solve it, you may need to have it looked at by an appliance electrician.
Oct 21, 2012 | Kitchen Ranges
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
R rear burner not sparking
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
When I turn the surface control to lite sparks come from the other surface controls. The burner does come on but we are afraid to leave the burner because of the sparks coming from the other controls. Do...
When one burner knob is turned to the light position, all burners will spark. Once the burner lights, just move the knob slightly so it is no longer in the light position and all sparking will stop.
Nov 12, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Bosch Evolution 700 Series HGS7282UC 30" Freestanding Gas Range with 5.1 Cu. Ft. Capacity, Genuine Logo
16 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
