Question about Canon imageRUNNER 1023iF Black and White Copier
Machine shwos to clean platen
How do I clean the platen and reset it
Canon ir 2318 shwos "out of toner.I unpacked the
this is the common problem with 2318. u have to take out the developer assembly out and if u are a rep then check the toner shutter in the dev assembly.it some times does not move in accordance with the toner cartridge. u have to align it with cartridge in home position. and be sure to check the toner cartridge sometimes the churner in the cartridge is broken but 90% is the above said
Jun 03, 2011 | Canon Office Equipment & Supplies
The ink absorber is full
So you probably have a Canon Pixma printer with an error code E27 = "Waste ink absorber full or platen waste ink absorber full".
These two tutorial videos will teach you:
1. How to clean the MAIN ink absorbers: http://www.youtube.com/watch?v=VVpjqBr7KjU&feature=fvwrel
But there's a second ink absorber - the PLATEN one - which he does not talk about. The PLATEN is in the black plastic directly underneath the printhead as it slides back and forth. CLEAN THE PLATEN TOO before following the Part 2 video to reset both the MAIN and PLATEN ink absorbers in your software. And don't repeat his mistake when putting the printer back together - the springs he points to at 4:30 WILL fall out!
2. How to reset your printer's internal firmware to remove error alert: http://www.youtube.com/watch?v=4IrBdw7el2E&feature=fvwrel
P.S. Of course it is much easier to bring it to ther printer service (even better if your warranty service can do it for free, if the full ink absorbers error was not caused by too intensive printing, i.e. not your fault).
Mar 06, 2011 | Office Equipment & Supplies
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Waste ink absorber is full
Hi there
Mar 14, 2010 | Canon PIXMA iP1600 Printer
CANON IR1022A PLATEN GLASS
Once you clean the glass, you must power down the unit completely. They error won't reset automatically.
Mar 05, 2010 | Canon Office Equipment & Supplies
How to replace ink absorber for Canon PIXMA iP1200
Canon Pixma iP1200 Resetter
Oct 25, 2009 | Canon PIXMA iP1200 Photo Printer
Wide black line down page
open the document lid. Check to see if there is white-out on the glass platen where the document rides across the scanner. Some units require the white roll to be taken off.
sometimes a black mark on this platen can leave black streaks on copies made on this machine, and even when they send to others.
Try to clean the platen glass.
Oct 15, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Canon Pixma ip1700 how to clean a full ink observer?
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
2. Unzip downloaded file by etc
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jul 08, 2009 | Canon PIXMA iP1600 Printer
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Canon imageRUNNER 1023iF Black and White Copier Logo
16 people viewed this question
old marine
old marine
