Question about Ryobi Gas Pressure Washer: 3100 psi 2.5 GPM Honda Engine with Idle
Power washer froze over winter now no pressure?
Troy built pressure washer leaking out port in bottom of pump?
sounds like it might have froze over the winter
May 15, 2015 | Garden
Leaking power washer
I suspect that the pump froze with water in it over the winter.
here is a link to the replacement pump head kit.
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Mar 31, 2014 | Garden
Help, my power washer is LEAKING!!!
was water left in the washer for the winter and it froze ?ice expands and brake stuff like that
May 20, 2012 | General Garden
. it was in the
I believe it had water in it and it froze. My did this and I had to open it and replace a plastic
tube which cracked when the water froze. Very important to completely drain or place in a place where it won't freeze.
Apr 22, 2011 | Garden
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
Water leaking out of bottom of washer
It sounds like water was left in the pump and i froze over the winter and cracked the pump housing. You can try taking the gun hose off and blow compressed air where the hose hooks on to blow waterwater out of the pump and dry the bottom. Then put some apoxy on the crack to seal it.
Mar 18, 2011 | Karcher 2500 PSI Pressure Washer
The water pump
Any possibility the unit froze this past winter? They do have to be winterized.
May 05, 2010 | Honda Karcher G2400HH-R Pressure Washer
No pressure
Any chance it froze during the past winter? They do need to be winterized.
May 04, 2010 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Water is not coming out of my honda pressure washer
Any chance it froze during the winter? They do need to be winterized.
May 04, 2010 | Honda 8 HP Engine
Ryobi Gas Pressure Washer: 3100 psi 2.5 GPM Honda Engine with Idle Logo
67 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
