Question about Garden
Hello I have a Craftsman eager 1 Lawn Mower model 917.377591 the engine is a Tecumseh model 143.986700 The mower start's then dies it has fresh gas as well Iwent ahead and checked the spark plug and cleaned it plus checked the gap. Tried to start it again with the air filter off it started and died again. Next I took off the air filter assembly and notice the breather hose had a inch long crack at the end I need help on where to start to get the breather hose off to replace it Thank You
  • 376 Answers
The breather hose has nothing to do with it not starting. It starts when you prime the carb and dies when that gas is used up. Being a Tecumseh. it's most likely the bowl nut/jet stopped up. Unscrew the bowl nut and clean it. Look cery carefully at the top of the threads. There is probably a very small hole there also and it will not run if it is not open.
Posted on Jun 20, 2009
Testimonial: "Carb kit was on the money installed it on8/20/09 Started and Runs fine"
  • Dwain Pippen Jun 20, 2009
    Sorry, I just looked at the breakdown of your engine and I was mistaken about the type of carb you had. I was thinking you had the metal bowl type, but yours is the plastic bowl held on with a metal bale. You best solution is to buy a bowl kit, part # 730637A. It is a complete kit and just snaps on the bottom. There are several rubber 'o' rings and jets, etc in your old one that deteriorate over time. You would be much better off buying the bowl kit. About $20
    Scholar:
  • 81 Answers
Looking at the specs on this model it appears you just pull the breather tube loose at each end. If there is a small clamp that isn't shown on the specs. just pry them open and remove. The part number for the tube is 32447. Any small engine repair shop should have it in stock. Be sure to get the right one as these tubes are different lengths and have different bends in them that control the air flow for proper operation.
Posted on Jun 19, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I mixed up one spring and the mower idles low on craftsman eager-1 5.0 22 inch cut
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
May 14, 2011 | Craftsman Garden
Craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Aug 31, 2009 | Craftsman Garden
Looking for a manual on a Craftsman Eager-1 lawn mower. Model #131.90300. Sears has discontinued the manual
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Aug 11, 2009 | Craftsman Garden
Oil drain
Under cutting propller box
Jul 07, 2009 | Garden
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
Hard to start, when it does start only runs for a few seconds.
You need a full tuneup which means after the spark plug you need to do all of these and you will have a good running mower.
Drain gas tank.
Take carburetor off and clean it.
Pull the top off the engine and clean the flywhee maginets and the coil face with a small wire brush of emery cloth.
Clean screen in gas tank if there is one.
Fuel filter if the is one.
Be sure to check for a good spark after all this is done.
If this is all done you should have a good running mower.
donnyb60
Mar 20, 2009 | Garden
Garden Logo
1,638 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
