Question about Dryers
Dryer turns off mid cycle and display stays on minutes left in cycle but the ''sensing'' light comes on. HElp
  • 121 Answers
It sounds like you have a venting problem and your vent needs to be cleaned out
Posted on Jun 18, 2009
Why does my dryer shut down before the clothes are dry?
Bill, probably a bad moisture sensor, if you can locate sensor you may be able to clean it. See links below for more info.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.partselect.com/Repair/Dryer/Shuts-Off-Too-Soon
What to Check when your Dryer Shuts Off Mid Cycle
Appliance Repair Forums
Clean Your Dryer Moisture Sensing Electrodes to Ensure Proper Automatic...
Mar 03, 2016 | Whirlpool Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
I've a whirlpool sixth sense washer and the clean pump light comes on mid cycle. I've cleaned the pump filter, cleaned the pump, checked the pipes for blockages, and today replaced the pump, only to fine...
You might have a loose connection to the pump or from the pump to the CCU Remove the top of the washer and make sure that the wire coming from the pump to the CCU is fully in and it's not loose
Apr 30, 2014 | Washing Machines
DRYER RUNS SOMETIMES MID CYCLE DRUM QUITS TURNING BUT STILL HEATS UP COMES BACK ON AFTER A FEW MINUTES
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 26, 2011 | GE Dryers
Dryer will not start cycle
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Feb 18, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer keeps turning off mid cycle. Fuse is OK.
u may have blocked air flow that is tripping a resetable limit switch. if i had a model # that would help.
Jan 31, 2010 | GE Spacemaker Washer and Dryer Electric...
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Marvin
Marvin
